Old 05-19-2021, 05:15 AM   #1
Odd electrical issue
So yesterday I go to the parking lot and hop in my car and turn the key and nothing happens. Nothing at all. I notice I have no power.
I open the frunk and take the battery cover off just to see if there is anything worth noting, which there wasn't. I closed the hood, and as soon as it dropped closed, the car started chiming and the radio came on. So I hopped back in, turned the key, and instead of starting, all the power shut off again.
I once more opened the hood to make sure there wasn't a loose connection to the terminals. (There was not.) I closed the hood again. As soon as the hood dropped shut, everything came back on. Once more, I jumped in and turned the key. Nothing.
I once more opened the battery compartment, and out of frustration, I smacked the top of the battery with my hand pretty solidly and everything turned back on. I got in, it started right up and I have had no issues since yesterday afternoon.
Is this likely to be a harness issue, or did I simply need to reassert my dominance?
Current Rides
'99 986 (Glacier White) | '21 Telluride Nightfall SX Prestige (Dark Moss)
Past Rides (Highlight Reel)
'89 XJS (Solent Blue) | '85 XJ6 (Steel Met.) | '93 XJ6 (British Racing Green) | '35 Bugatti Type B (White) | '04 Mustang GT Premium (Silver) | '79 Camaro Berlinetta (Carmine)
trilobite is offline   Reply With Quote
Old 05-19-2021, 05:23 AM   #2
1999 Boxster 5 spd.
If you can get everything to work simply by hitting the battery and if all of the battery connections are tight, I would assume it is a battery issue.
99 Boxster 5 spd, Arctic Silver
Dayton, Ohio
Huey is offline   Reply With Quote
Old 05-19-2021, 05:56 AM   #3
I would double check your cable connections with a wrench. Mine will short out if the ground isn't really snug on the terminal.
Sent from my POCOPHONE F1 using Tapatalk
Old 05-19-2021, 05:56 AM   #4
Remove , clean and reattach your battery clamps. Check, clean and tighten the positive cable where it attaches to the frame of the car.
Old 05-19-2021, 07:52 AM   #5
Thanks, guys! I'll try taking it out, cleaning everything, and reattaching everything wrench-tight.
Current Rides
