Old 05-15-2021, 05:46 AM   #1
PLP
PLP's Avatar
Climate control errors - mixing flap, recirculation/fresh air. MOST reset?
Not sure if that is all caused by the aftermarket radio install... which was a bit sloppy, if you ask me.
Here is the screen shot from Durametric.
Symptoms: no heat although the heater core is hot. Error 26 Mixing flap motor fault
While researching it, I confirmed the fresh air/recirculation flap does not actuate either.
What works?
Basically everything else is fine.
I can change the temperature, adjust the blower, change direction of the air. It also works fine in automatic mode.
I also have the foam flying around. I know this one and solution for it. I will get to it eventually.
So, my work around during 15 hours drive in cold weather, where 6 were in rain, and another 3 in snow.
I managed to squeeze my hands under the flap motor and disconnected the arm from the flap.
The flap dropped automatically to the hot position. I could easily move it, so I know it has free movement.
Heat started blowing right away and I could continue my journey.
Anyway, what we could do here? What am I looking at?
Also, would the system be in German language?
It shows F for temp, but MANUELL for manual operation mode. Not sure if it has any significance here.
This is one I am not sure how to bite. Not only poor access, but some wiring messed up from the radio install.
PLP is offline   Reply With Quote
Old 05-17-2021, 04:55 AM   #2
PLP
PLP's Avatar
Update.
Guess what caused it? I would never got there if I was not deep cleaning the car.
Just by my "attention to details" I noticed that one pin on the black connector to the climate control unit sits a bit further than others.
Pulled the connector out, fixed the lock on the pin, pushed it back in, reinserted the connector, and all of sudden I can hear a motor spinning.
I reconnected the arm to the flap and temp mixing flap is working fine.
The PCM timeout is, I bet, radio related.
It is a problem on the long run?
Old 05-17-2021, 08:38 AM   #3
No, not an issue. Just means the connector isn't plugged in that detects the factory radio. it's fine.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
