Old 04-27-2021, 06:57 PM   #1
PhoenixBlue
Airbag Light Fault Code - Left Rear Side Ignition Squib
Hi All! Just got a 2000 S, and one of the issues that we are dealing with is an airbag light (also rebuilding the tiptronic ‘box, and installing new brakes). Seems to be an issue on the left side, and I have been reading about the possible fixes including seat belt buckles, wiring and control unit replacement, but nothing about “ignition squib” pops up.
Unfortunately I can’t find these exact fault codes when I search online. Is my mechanic using the right scan tool? Anything I’m missing here? Any help would be great, thanks!!
PhoenixBlue is offline   Reply With Quote
Old 04-27-2021, 07:39 PM   #2
911monty's Avatar
A squib is a small ignition device (think blasting cap) that ignites the explosive charge in the airbag.
Old 04-27-2021, 08:31 PM   #3
It is most likely the seat belt retractor. I'm going to guess that it's been in an accident before cause that's the only time you would get that code....or the wiring to it is bad
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 04-29-2021, 07:56 PM   #4
PhoenixBlue
Thanks for your help! They have tried to troubleshoot, and apparently think that it is an instrument cluster fault - everything else was okay. Have to look for a replacement cluster now 😔
Old 04-29-2021, 10:03 PM   #5
it isn't the cluster
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 05-01-2021, 12:58 AM   #6
PhoenixBlue
Update - change to a used cluster did the trick! Let’s see if the light comes back... thanks for all your help!!
