Old 04-25-2021, 01:06 PM   #1
Does this look like a bad bleeder valve or broken tank?
I noticed some coolant on the floor of my trunk.
My assumption was a cracked tank, but the coolant appears to be coming from the black plastic portion. Is this a symptom of a bad bleeder valve?
[Edit: picture upload on this forum is near impossible]
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
Old 04-25-2021, 01:55 PM   #2
if you are getting cooling in the trunk it's going to be a cracked tank 90% of the time
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 04-25-2021, 01:57 PM   #3
That was my assumption, but the fluid is coming from the very top of the black plastic, which makes me wonder if it is the bleeder. I Wish I could get a picture to post here
98 Arena Red 986
Old 04-25-2021, 02:03 PM   #4
In the pic below, the fluid is indeed coolant.
98 Arena Red 986
Old 04-25-2021, 02:04 PM   #5
98 Arena Red 986
Old 04-25-2021, 02:20 PM   #6
Originally Posted by Stroked & Blown View Post
Pressure test the system then you will know where the problem is.
Harbor Freight has coolant system pressure testers for a reasonable price.
They will work on any cooling system.
Old 04-25-2021, 05:14 PM   #7
Agreed. Pressure testing is the quickest way to find most coolant leaks. Mine turned out to be the bleeder valve.
Sent from my Pixel 3 using Tapatalk
RobT987 is offline   Reply With Quote
Old 04-25-2021, 07:15 PM   #8
Motorist & Coffee Drinker
78F350's Avatar
It looks like the plastic has turned yellow. Originally it's white. Even if it isn't cracked now, it's days are numbered and you'd be best off replacing the whole tank at a time of your choice (soon) rather than leaving the timing to fate.
Old 04-25-2021, 10:03 PM   #9
Take it from someone who had one fail 50 miles in the middle of a national park (and on a mountain: great tow bill!!) do it now!
-H. L. Mencken
Old 04-29-2021, 07:56 AM   #10
Rob175's Avatar
My 98's tank "gave up the ghost" last year due to tiny spider cracks on the bottom that would expand once the coolant got hot and the pressure began to build. Once it cooled down the cracks would close up and it wouldn't leak..........$875 later (spent with my "indi" mechanic) I got a new Porsche brand tank, hoses and clamps installed.
Rob175 is online now   Reply With Quote
