you can't remove the immobilizer or bypass it. Just that simple. The DME looks at the immobilizer & the key and if everything doesn't match the car wont start.
What you could do is wire up an aftermarket alarm/keyless entry like the viper I mentioned and use it to lock/unlock & do trunk pop. No experience with that system you linked to and honestly it isn't something I would use. |
| All times are GMT -8. The time now is 08:25 PM. |
