Old 04-16-2021, 03:50 AM   #1
Piston ring end gaps.
Continuing with the rebuild of my 2.5 M96/20 engine...I am now ready to install pistons 1/2/3...checked the ring gap with a piston to keep the ring square in the bores...all 6 top ring are between .014" & .016" I,m happy with those...BUT...all the second ring gaps are between .034" & .036"...normally they would be .002" larger than the top ring gap...these are new Mahle rings & my bores are very good condition wear wise...surely those 2nd ring gaps are much to wide for new rings...I,ve seen rings with less gap after 2 hundred thousand miles...anyone have the correct Porsche spec ring gaps.
EMWynne is offline   Reply With Quote
Old 04-16-2021, 07:27 AM   #2
I just checked the factory workshop manual, no specs listed there. Sorry dude.
Old 04-16-2021, 11:23 AM   #3
piston ring gaps.
Thanks Ike...that seems to be the problem, none of the manuals give the specs because they did not expect the engines to be rebuilt...but people are rebuilding...you can now buy all the parts required...so somewhere there is the correct specs.
Old 04-16-2021, 12:14 PM   #4
I replaced the rings in my 99 Boxster because the ring gaps were pretty large at the oil rings. Here you find some reference about the gaps of used rings versus the new set I used:
Blue boxster resurrection project
Old 04-16-2021, 12:16 PM   #5
Oh, page #6 and #7.
Old 04-16-2021, 01:45 PM   #6
Thats definitely wrong. I aimed for 17 top, 18.5 2nd ring. .034...they sent you the wrong set
Old 04-19-2021, 08:12 AM   #7
Ring end gaps.
I have been chatting with my Porsche parts supplier & for those who said that 2.5 & 2.7 ring sets are different...he advised me THEY ARE NOT...all Mahle part number504-04-N0. standard...N1 for plus 0.010" & N2 for plus 0.020".
Old 04-19-2021, 11:42 AM   #8
Yes, I used 2.7 rings for my 2.5. The seller of course was convinced they won`t fit but I bought them anyway and they did. The stroke is different, the bore is the same.
Old 04-20-2021, 03:30 AM   #9
I have just had an e-mail from the Senior Product Manager at Mahle...he quoted the ring gaps for piston ring set 504 40 N0 for Boxster 2,5/2.7cc engines as,
Top ring-0,15...0,35mm....006"-.014"
2nd ring-0,60-0,80mm....024"-.032"
oil control-0,50-0,75mm...020"-.030"
a very wide 2nd ring gap but they are correct.
My rings are still out of spec. brand new.
Old 04-20-2021, 10:24 AM   #10
ring end gaps.
Homeoboxter, Where did you buy your ring set & do you have a part number...what did you set all your ring gaps to...because your car runs great with no problems...oil consumption etc.
Old 04-20-2021, 11:37 AM   #11
It`s been two years now, but I believe I had bought these:
https://www.ebay.com/itm/PR1400-Porsche-Boxster-H6-2-7-Piston-Ring-Set-00-08-/164155998893
I didn`t touch the gaps, wasn`t necessary. Look at the build thread, i think I listed there what the gaps were like with the old and the new rings.
