Old 04-14-2021, 10:12 AM   #1
LED capable turn signal relay
Hey guys,
I replaced the headlights in my 2000 S with litronics with clear bottoms.
When I did that I also replaced the turn signal bulbs with Philips LEDs.
Mostly for longevity purposes.
Anyways. When I first replaced them I checked that they were flashing right and not hyper flashing.
Apparently I didn't check long enough. They flash normally for 2 to 3 flashes and then starts hyper flashing.
So my question is. Does anybody know of a compatible relay that will support the LEDs or do I simply need to yank them back out ?
Thank you
2000 Boxster S Manual
Zordrack is offline   Reply With Quote
Old 04-14-2021, 10:52 AM   #2
78F350's Avatar
Do a web search for "Load resistor for LED turn signals".
Old 04-14-2021, 10:59 AM   #3
I was hoping to avoid that and solve it with a compatible relay.
Old 04-14-2021, 11:35 AM   #4
A load resistor both unnecessary and counter productive as it dims the light's. Amazon sells some digital LED flashers for less than $10.
Old 04-14-2021, 01:00 PM   #5
I bought this one. Works perfectly. I also installed very bright yellow LEDs at both ends of the car - great combination.
https://www.superbrightleds.com/vehicle/2001-porsche-boxster-hazard-warning-flasher?make=61&model=454&scc_id=1454&year=2001
ddruker is offline   Reply With Quote
Old 04-14-2021, 02:30 PM   #6
Awesome.
Thank you guys.
Had to completely replace basically all the lights on the car. Both housings and bulb carriers were broken beyond repair on both tail lights and the third brake light.
So got the Revi Motorwerks smoked LED third brake light and the smoked 718 style LED tail lights.
The car is all black so added the sequential LED side markers as well.
Dropped right in. Looks good and was less than buying new stock lights.
Already had all the interior and trunk lights replaced with the suncoast LED kit.
So when I got the litronics in I figured I might as well replace the last few tungsten bulbs with LED.
Position lights were already LED.
Got some yellow H7 LEDs for the fog lights and and amber LEDs for the turn signals.
I did leave the tungsten high beams though.
Didn't wanna risk burning the reflector or lens before doing some more research.
But it's all slowly coming together
