Old 04-12-2021, 04:52 PM   #1
Shacky
Passenger Door Sill Collecting Water
Boxster was out in rain last night. Upon opening passenger door I see the sill indent is pooled with water.
I'm assuming this is coming from window door. Has anyone else seen this happen?
shacky is offline   Reply With Quote
Old 04-12-2021, 05:04 PM   #2
Happens on my wife's 2000. Happens more then it's parked in our driveway which is at a pretty decent incline and less so when it's parked flat like the street or parking lot.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 04-12-2021, 09:51 PM   #3
Shacky
Have you figured out source of water entry?
Old 04-13-2021, 06:23 AM   #4
No. I dont think it's coming through the door/window though.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 04-13-2021, 04:27 PM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
What shape is the plastic sheet (the one between the door card and the metal door) in? If that isn't in good shape or sealed properly, it can allow water in. My experience during a regulator R&R and it started to rain midway through the project.
Old 04-13-2021, 04:45 PM   #6
he is saying the water collects between the bottom of the door & the sill, not that it comes inside the car which is what that plastic sheet is meant to keep from happening.
If it does the same thing as mine it just collects there and doesn't actually get into the car and as soon as you open the door out rushes the water.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 04-13-2021, 06:31 PM   #7
Shacky
Had indy install new regulator couple years ago and now that I'm thinking back this has happened before. I thought it was from window not going down properly upon opening door and when you close door the top edge sits outside the roof rail.
So I wonder how well they reattached that plastic liner. Since I have to pull door apart to fix the window anyway I'll see how it looks then.
Old 04-14-2021, 03:26 PM   #8
Shacky
Here’s pic of area with water
180C9F4E-98FE-42A9-BC69-17D104C821F5_IMG_0475
Old 04-14-2021, 03:50 PM   #9
well that shows water getting in the car, not collecting in the sill. the sill is the silver area.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 04-15-2021, 11:17 PM   #10
Shacky
I'm thinking culprit is faulty window stop - if passenger door is closed without pushing top of glass in first the top sits outside of roof rail. I took my granddaughter for a ride the other day and may not have corrected window seal before it rained.
Old 04-16-2021, 12:37 PM   #11
2002 Boxster S
Make sure the water isn't getting under the drivers seat toward the immobilizer. If it does you're going to have bigger issues.
john12312 is offline   Reply With Quote
Old 04-16-2021, 02:22 PM   #12
No danger here as it is happening to the passenger side not drivers.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 04-16-2021, 03:44 PM   #13
Shacky
Made sure widow was properly closed. Rained hard all day - no water :dance:
