Old 03-26-2021, 04:30 AM   #1
Double Check on Wheel & Tire Fit
I'm needing a second opinion on if these wheels and tires will fit my 2001 Boxster. From what I've researched I believe they will but the guy selling them claims they are too big.
Front:
8x18, offset is 50 and tires are 235/40
Rear
10x18, offset is 41 and tires are 265/40
Thanks!
Steven
_________________________________________________
1975 914-6, 3.5l
2001 Boxster, 2.7l
sharper410 is offline   Reply With Quote
Old 03-26-2021, 04:48 AM   #2
husker boxster's Avatar
The rears could be sketchy. Use this calculator to see how the new wheel will fit compared to your originals.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
1989 928 S4 5 spd - black
Old 03-26-2021, 07:16 AM   #3
Also 235/40 18s will rub the fender liner in turns when lowered
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
Old 03-26-2021, 09:37 AM   #4
I have 235/40 on 8x18 et 50 on my fronts without issues. My suspension is stock except for gt3 LCAs. I can even use 5mm spacers without issue
The rears should be ok, but are a bit tall.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 03-26-2021, 08:08 PM   #5
I run 265/35 in the rear on stock springs without issues.
moosport is offline   Reply With Quote
Old 03-28-2021, 05:10 AM   #6
I run 235/40R 18 and 265/35r 18 everything stock no problem. If your wheels are 17 you'll notice that your mph will be off by about 3.
mtb50 is offline   Reply With Quote
