Old 03-18-2021, 01:40 PM   #1
Misfire on Cylinder 2,4 and 6 - Help!!!!!
Hello all.
So i have a strange issue - My 986 Boxster S - tiptonic is showing misfire on cylinders 2 4 and 6!
I have bought a new set of coils and new set of plugs for all 6 but still the same issue - what could be causing this issue on both banks!
Another fault it has come up with is P0413 0 Secondary air control valve A open circuit is that to do with the MAF and could that be the issue?
Thanks in advance!
Byrnsey2 is offline   Reply With Quote
Old 03-18-2021, 02:18 PM   #2
Always helps to know the year of the car...........
Old 03-18-2021, 02:51 PM   #3
I knew there was something missing - its 2004
Old 03-18-2021, 05:33 PM   #4
it's best to list all the codes. Are you using a generic reader or durametric? Are they pending or set?
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 03-19-2021, 02:47 AM   #5
These faults codes were brought up on the MAC Tools - Mentor Touch Pro Diagnostic Scan Tool
P0413 - Secondary air control valve A open circuit
P0300 - Random / Multiple Cylinders Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P0304 - Cylinder 4 Misfire Detected
P0306 - Cylinder 6 Misfire Detected
Thats all on screen
Old 03-19-2021, 06:49 AM   #6
porschefan76's Avatar
Thats all on screen
Hi Byrnsey. I don't want to send you down a rabbit hole, but have you taken a look at your fuel trims? Is the car running rough? If the problem with the SAI is causing a lean condition at idle (RKAT will be some value positive above 0) I'm pretty sure that can cause misfires especially at low RPMs. Here's a link from ScannerDanner that made me respond. As a symptom, he mentions that "customer has replaced plugs and coils in an attempt to fix". He is focusing on a leaking intake manifold gasket, but lean at idle is lean at idle (I think!).
https://www.scannerdanner.com/chapter-1-misfire-id-compression-test-vacuum-leaks-fuel-trim-head-gasket-restricted-exhaust-low-power-dvom/86-misfire-caused-by-a-vacuum-leak.html
If the car is running rough and you find that your fuel trims are indicating lean at idle, perhaps pull some of the vacuum hoses in the area of the SAI and test them with a vacuum hand pump to ensure they hold vacuum? There's also an electronic change-over valve in the SAI that you may be able to activate within Durametric to aid in diagnosing. Here's a link to keep you on track if you start to pull and test those vacuum lines:
Vacuum line clarification
Best of luck!
porschefan76 is offline   Reply With Quote
Old 02-06-2022, 01:07 PM   #7
Hello all.
Thanks in advance!
Hi Byrnsey2, I just experienced misfires on Cyl's 2,3 & 6 last night all at the same time. The car has been running better than ever!
Did you end up figuring out why your's was doing this???
GreekBoxster is offline   Reply With Quote
