Old 02-22-2019, 02:11 PM   #1
2004 Boxster S - Doesn’t Start!!
Hi Everyone
So today my 3.2l, 2004 Boxster S failed to start!
Drove around 40 miles in it no issues. Stopped and a friend house and then the car wouldn’t start. Started chugging for a little bit and cut out.
Called out the AA and they said that it May be the fuel pump and found no amps going to the fuse
so what would people suggest?
Relay? Fuel pump? Please help!
Byrnsey2 is offline   Reply With Quote
Old 02-26-2019, 08:29 AM   #2
Crank shaft position sensor?
Is she throwing any codes?
Luckyman01 is offline   Reply With Quote
Old 02-26-2019, 09:13 AM   #3
Multi-Boxer Driver
Deserion's Avatar
Check all of your fuses first and foremost. Redundant, yes, but best to clear the easiest options first.
If the fuel pump is found to be fault, DO NOT replace it without replacing the sending unit as well - Porsche idiotically integrated the fuel filter into it in 2002. I had this issue several years ago where I went through 2 brand new OE fuel pumps then discovered my filter was clogged. This, of course, was after having a no-start issue where it would crank (tach moved), but had no fuel at the rail. In that scenario I had also replaced the fuel pump relay.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 02-27-2019, 03:11 PM   #4
My problem turned out to be a weak "positive" ground in the engine compartment. It was rusty, and if I wiggled the cable and turned the key the engine would start. Disconnect the battery. It is located in a black plastic box next to the power steering reservoir. Use a screw driver to pop the box open and a 14 mm socket to remove and clean the nut.
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
Old 02-27-2019, 03:38 PM   #5
Multi-Boxer Driver
Deserion's Avatar
Thanks for sharing the conclusion. I had that cable off recently when replacing the voltage regulator.
-Chris
Old 02-27-2019, 03:51 PM   #6
Not the OP
I am not the "original poster" ...just sharing what my problem turned out to be ...
Old 02-27-2019, 04:09 PM   #7
Fuel pump relay? You can google search to see how to jumper it for testing or pop in a new one and keep the old one for a spare if its still good.
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
Old 02-27-2019, 05:50 PM   #8
Multi-Boxer Driver
Deserion's Avatar
It would help if I had read who posted it. Whoops. I’ll just blame it on being on my phone.
-Chris
Old 12-16-2019, 04:01 AM   #9
Did this turn out to be a crank angle sensor problem?
Silver' is online now   Reply With Quote
Old 12-16-2019, 05:45 AM   #10
This was the fuel pump on this occasion - £200 for new part.
The car wont start again now, last time it tried to crank but this time not at all now
Boxster S Tiptonic -2004. Will Not Start
Old 12-25-2019, 05:19 PM   #11
Old 03-06-2020, 08:09 AM   #12
Brian Minson's Avatar
For anyone else having fuel pump problems, here is a video I did on how to test the fuel pump.
https://youtu.be/wEWepuDUes4
Brian
Brian Minson is offline   Reply With Quote
Old 03-18-2021, 01:44 PM   #13
So fist time it would not start (but would crank) was fuel pump issue
second time 6 months later would not start was water in the immobiliser
Old 03-18-2021, 03:19 PM   #14
You are aware of keeping your drains cleaned out.
mtb50 is offline   Reply With Quote
