bubbling paint
I have two spots on my 97 986 where the paint is starting to bubble. Will this be covered under the corrosion warranty?
Thanks Automon |
How long is the corrosion warranty? Longer than the standard warranty? I have no idea, but I would guess a 97 isn't going to be under any kind of warranty anymore given the age of the car.
I believe there is a 7 or 10 year rust warranty. Check your owners manual. :)
Where is it starting to bubble?
under the drivers side air intake my owners manuel says 10 years so I guess i will take it in and see what they say. Has anyone else had this problem?
Thanks, Automon |
If it is right under the lip of the air intake scoop it is possible that some water containing some corrosive minerals was trapped in there for a long time. I think the corrosion warranty should fix it for you though. Good luck and let us know what happens! :)
In my experience, normally a corrosion warranty only applies to what they call "perforation", or a complete rust-through problem. Hopefully, the Porsche warranty is more gracious and you'll be covered...
| All times are GMT -8. The time now is 02:54 PM. |
