Old 02-23-2021, 06:12 AM   #1
Veteran & Boxster Padawan
Farmlifer's Avatar
Headlight Switch?
Hello Forum,
So, I picked up my “new to me” 2003 Boxster in California and on the drive back noticed low beams would not always come on first try (maybe second, or third, or more, or if I flipped on high beams and flipped back lows would then work).
Easy headlight switch DIY or something more complicated within wiring or headlight assembly???
Thanks for any troubleshooting assistance and DIY tips!
(Apologize for duplicate posts unable to delete copy)
2003 Boxster / Speed Yellow / DRL Hack
Farmlifer is offline   Reply With Quote
Old 02-23-2021, 06:59 AM   #2
I think you're probably on the right track, and the switch itself is fairly inexpensive and easy to replace. YouTube search will walk you through it and it takes less than an hour.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 02-23-2021, 03:16 PM   #3
Farmlifer's Avatar
Thank you ✅
Old 02-23-2021, 06:38 PM   #4
KevinH1990's Avatar
You can also use electronic contact cleaner to clean the switch.
KevinH1990 is offline   Reply With Quote
Old 02-24-2021, 05:13 AM   #5
Farmlifer's Avatar
Worth a try guess I just pull off the knob and give it a few squirts worst case replace switch anyway if no improvement - thanks haven’t seen that stuff since Radio Shack days... ⭐️
Old 02-25-2021, 06:30 AM   #6
Note that although the light switch is most likely your culprit, the wiring insulation inside the headlight assembly breaks down over time and can cause lighting issues. It costs $0 to pull the assembly and take a peek inside.
Old 02-25-2021, 07:06 AM   #7
Farmlifer,
A general rule to keep in mind when working on any aspect of an automobile.
Simplest things first. then work step by step up the system from simplest to most complex.
So for example as in your issues:
fuses
bulbs
wiring
connections, at the bulb, wiring harness, at the switch, etc, etc,
switches
What this does is helps prevent spending money and replacing parts needlessly when perhaps the problem was something very simple and basic.
I have seen people replace starters just to find out that they had a bad connection at the battery
Hope this helps.
