Old 02-05-2021, 09:09 AM   #1
Trailing Arm Alignment Quality Control?
Hey all, long time reader first time poster and all that jazz.
Anyway, my dad's 986 had a messed up front control arm ("wish bone") and drive axles. So I decided to DIY new axles into it and replace the control arms on all 4 corners.
Everything went fine. The trailing arms in the rear looked good so I decided to reuse them. I stupidly stripped the threads on one trailing arm so I bought the cheapest replacement I could find (since I'm buying the car off my dad, my thought was that I would use a cheap one now for the next few years until I move back to the US full time and replace everything again to turn it into a track car). Normally I will not use cheap parts but I just needed 2 years of very light driving.
Anywho, since I'm not a wizard I took it in to an actual pro for the alignment portion, the car would lurch a bit to the left going over bumps at speed, indicating to me an alignment issue on the trailing arm. So the shop doing the alignment calls and says they've done everything but can't get the wheel that I did the trailing arm on in alignment.
My questions boil down to, I failed to compare the old part to the new cheap part. Could it be that the cheap part was messed up? Could I have messed something up in the installation process? I didn't compare the old part to the new one, it was the last thing I needed so once it came I put it on, lowered the car, tightened everything and drove off to the shop. Either the arm is messed up from the cheap factory, I screwed up, or the shop doesn't like DIY work. My dad trusts the shop so I'm not going down that route. Is it likely that the part was wonky from the get go?
stofenism is offline   Reply With Quote
Old 02-05-2021, 11:32 AM   #2
BYprodriver's Avatar
Only use TRW part, I bought a new URO control arm that only lasted 50 miles.
Old 02-05-2021, 02:30 PM   #3
Damn Yankee
TeamOxford's Avatar
Originally Posted by stofenism View Post
....so I bought the cheapest replacement I could find
Chances are you bought a URO product, as they generally are the cheapest parts available.
BTW, URO stands for:
U
Replace
Often
They are known for their inferior quality parts
Like Bill, I only use TRW suspension parts.
Just sayin'........
TO
Old 02-06-2021, 05:00 AM   #4
I replaced my trailing arms two years ago with URO parts and they've held up rather well without any signs of wear yet. Not arguing about their quality, just my experience.
What could they not get lined up? The camber or toe? That makes a big difference in where to look for issues.
What exactly did you strip? If the mounting hole on the frame got buggered up I could definitely see that causing an issue. That may be the actual problem, and not the arm itself.
