Old 01-18-2021, 04:16 PM   #1
What should I be investigating
Hey guys, had my 2.5 1997 for about 5 months now and I’m in love with it, done 5000 miles so far already!
What I will say is this car has been nothing but a pain in the ass so far in regards to maintenance I replaced the blower motor because it sounded like an attack helicopter, had an alarm issue which I got rectified, there’s a few I’m stumped by
Front left knock, sounds like someone is playing a drum down there, when I’m by myself it’s knock squeak knock squeak, I asked the old man for his advice, he’s a mechanical engineer and has a lot of knowledge when it comes to almost any vehicle, we had the wheel off, investigated, everything looks solid, no play anywhere, I’m confused! Took him for a drive to listen and for the first time ever no noise at all!! It’s always noticeable by myself
What could be causing such a loud knock constantly?
Not sure if this is normal, obviously there’s a certain level of deceleration noise if you were to downshift or whatever and let the revs drop but in 1st and 2nd gear I seem to have a really noticeable whine when accelerating or decelerating, that seems to be most noticeable in the 2000 revs range. 3rd gear is very very slight and as you change up there’s no noise at all, I don’t have any gearbox or clutch issues in regards to shifting.
Any ideas on what to investigate for these? I’m off work at the moment so I’d like to take this time to get ontop of things, cheers!
Corey Hill is offline   Reply With Quote
Old 01-18-2021, 06:40 PM   #2
Trailing arm or LCA ball joint.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 01-18-2021, 06:42 PM   #3
Trailing arm or LCA ball joint. Nothing recreates the stresses of driving when the wheel is removed. But if it is whine from the front may be a wheel bearing. You are describing 2 very different issues - a knock & a whine.
Old 01-18-2021, 08:33 PM   #4
Worn out trailign arm causes the knock and the squeak is caused by LCA gone bad. At least what I had and by replacing those, the noices disappeared. Same like with you, the wheel off there was no any signs of problems to be found...
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
Old 01-19-2021, 02:17 AM   #5
Thanks guys, decent food for thought and sounds like that’s what I should be looking into
