Old 09-18-2020, 05:54 PM   #1
Wiring AMP Outputs
2004 Boxster S
5 channel AMP
Factory BOSE system with rear deck subs.
How would you wire this? Ignore the Blue pair as they are the rear tweeters i believe. Wire channel 1&2 to the dash, 3&4 to the doors, and the mono sub output to the large white and brown pair for the subs?
http://imgur.com/a/GFJRjMv
HorsiesInDaBack is offline   Reply With Quote
Old 01-14-2021, 08:21 PM   #2
We recently purchased a 2003 BoxsterS with the Bose system. Previous owner installed a Kenwood deck and the rear speakers are not hooked up. The front door & dash speakers are not wired correctly either. I was curious if you were able to get your wiring issues sorted? I appreciate the wiring diagram you posted in the link. I purchased the Bentley Boxster Service Manual but I can not find the wiring diagram that you posted. Is there a way to use the factory amp? Thanks!!
Road Racer is offline   Reply With Quote
Tags
amplifier , bose , radio , wiring
