Old 12-14-2020, 02:42 PM   #1
gabedrummin's Avatar
Cam timing
I need an experts opinion . I installed the cams with 7 links between the dots on the camshafts with the crank locked at the correct position for bank 1 then rotated the crank 360 and locked the crank and installed the cams for bank 2 . Are these timing marks close enough ? Thank you all don't want any more problems .
gabedrummin is offline   Reply With Quote
Old 12-14-2020, 02:49 PM   #2
second pic
Last edited by gabedrummin; 12-14-2020 at 03:38 PM. Reason: delete pics delete post please
Old 12-14-2020, 06:07 PM   #3
I`m certainly not an expert here, but on a 5 chain engine there should be 6 links in between the intake and exhaust cam marks... how did you count 7?
Useful links, just in case:
Install Head 4-6
Blue boxster resurrection project
Old 12-15-2020, 01:51 PM   #4
Just like in your the first link from the dot its on is one then the last link one the second dot is 7 ...6 links in between the dots yes ..
Old 12-15-2020, 02:07 PM   #5
Ok, I think you should be good then. Rotate the crankshaft a couple times and make sure the camshafts line up at TDC.
