Old 11-22-2020, 10:53 AM   #1
odometer reset
I have a 2003 Boxster S. 986. I can confirm without reservation that the Xtool X100 Pro2 scanner changes the odometer to whatever I want it to say with incredible simplicity. Hook up to OBDII select dashboard, select Porsche 986 select change mileage save present setting, put in desired mileage and go.:dance:
obthomas is online now   Reply With Quote
Old 11-22-2020, 02:52 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
That is a scary thought.
Old 11-22-2020, 03:35 PM   #3
Assume you did this for the 996 gauges you installed? The listing in Amazon says it doesn't do mileage but it does keys, remotes and immobilizers for 2000-2014 cars. I wonder if it does Porsche key programming.
Old 11-22-2020, 06:32 PM   #4
Qingdao's Avatar
hehe a master porsche key... and you can change the mileage at will. I like this ultimate thief's tool. It should come with an angle grinder so you can remove the VIN plates. LOL
'98 PP13B powered "RX986"
Old 11-23-2020, 11:14 AM   #5
JayG's Avatar
You do realize that changing the odometer mileage for other than a replacement dash is very illegal
Old 11-24-2020, 07:28 AM   #6
That is exactly what I did. I changed my 2003 986 cluster to a 2002 996 cluster and adjusted the miles on the 996 cluster to match the actual miles on my boxster.
Old 11-30-2020, 09:06 PM   #7
Of course, a CarFax report may not agree with the odometer.
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
BoxMann is offline   Reply With Quote
Old 11-30-2020, 09:50 PM   #8
traveno's Avatar
odometer reset
This is actually pretty intriguing. I want to put a 996 cluster in my 986. I planned to have to pay big bucks to send my 996 cluster off for a odometer adjustment and possibly wait weeks for it. In that time, I couldn’t drive my Boxster, obviously, or my miles wouldn’t match my new cluster. Now I could just do it in my garage.
How does this tool compare to the Durametric tool that everyone seems to recommend?
2001 Tiptronic S in Speed Yellow
traveno is offline   Reply With Quote
Old 12-01-2020, 04:29 PM   #9
amagalla's Avatar
Keep in mind that you'll also want to change the VIN in the new cluster. I did it with an eprom programmer. It's a little scary that you can change the odometer reading from a hand held scanner.
Tony
Lapis Blue 03 Boxster S
Old 12-02-2020, 06:27 AM   #10
I want to change the VIN but the scanner will not do it. I read somewhere if I set the odometer to roll over to 0 that it will boot like a brand new cluster and look for the VIN in the ECM and copy it. I do not know if this is true, maybe someone will chime in. I am not computer literate enough to remove the Eprom and reprogram it.
Old 12-04-2020, 05:37 AM   #11
You don’t have to remove it and if you can click “copy and paste” on a mouse, you can do the eeprom.
Doing it that way ensures that everything is copied over and you aren’t supporting the makers of a thieves tool.
Old 12-04-2020, 08:48 AM   #12
I also did the 996 cluster swap in my 02 track car with a eeprom programmer. Did both mileage and VIN.
swmic is offline   Reply With Quote
Old 04-15-2021, 03:03 PM   #13
I know I’m resurrecting an old thread but I have a 996 gauge cluster in my 986 and I want to sync up the mileages. The Aurelio Mk808 does not do Porsche mileage changes.
I bought an eeprom reader but I am having a hard time making it work. I connect the clip to the chip on the board but nothing happens on my computer. I bought a cheapo chip programmer on Amazon and I wonder if I don’t have what I actually need or if I am just doing it wrong.
What chip programmer hardware is good? Do I need a program for the computer to read and write values? From what I was reading in the Amazon page it seems like the seller is saying once it detects a chip the app should just pop up but I didn’t install anything special.
This is what I tried following and didn’t have any luck. https://rennlist.com/forums/attachments/boxster-and-boxster-s-986-forum/1304533d1559093466-cluster-upgrade-working-with-the-eprom-on-porsche-boxster-illustrated-old-and-new-style-clusters-minimum.pdf
Both Boxsters I need to do are late-style cars, a 2001 and a 2004.
I super appreciate the help, thanks!
Lugnut is offline   Reply With Quote
