I doubt you can cut the oil and volt gauges off of a 996 cluster and graft them to your 986 cluster as there is likely one continuous circuit board across the back of all of the gauges. You can swap the entire cluster with a 996 cluster from the right year and the same type of transmission, but you need to have a specialist reset the mileage if that is important to you or legally required. Pelican Parts has a how to project article on the gauge swap.
