-   -   Air Bag - Interesting Observation (http://986forum.com/forums/boxster-general-discussions/78863-air-bag-interesting-observation.html)
930turbo 10-03-2020 09:10 AM
I get an occasional air bag light on my 2001S, driver side seatbelt buckle. I have the Durametric cable so I can easily reset it, which I've done several times. I have the service history where the previous owner paid significantly to replace the buckle so I believe this has been an issue for a while and the buckle didn't fix it. What I have discovered is the air bag light only occurs after the car has been jacked up off the ground. It's on after every oil change, tire change or any service off the ground. Most recently I installed wheel spacers one wheel at a time and upon completion the light was on again. It's too consistent to be coincidental. Has anyone else experienced this? I see mechanical ride height monitors on the suspension, could they somehow be related to the air bag?
930turbo 03-07-2021 11:10 AM
For follow up to this post. This theory still holds true. I had the tires replaced and when I went to pick the car up from the tire store airbag light was on again. I reset it and I’m sure I won’t see it until the next time it comes up off the ground.
thom4782 03-07-2021 02:16 PM
Buckle or buckle receptacle? The latter causes the issue
