Old 09-28-2020, 07:52 AM   #1
Shacky
Clogged front driver’s side drain
I got the passenger side unclogged using tuba cleaner. Passenger side is proving harder and I now see water has leaked into drivers side ruh.
Is there a plumbing drain solution or instrument anyone can recommend?
shacky is offline   Reply With Quote
Old 09-28-2020, 10:58 AM   #2
1998 Boxster Silver/Red
So... no water comes out fron the bottom river's side... when you pour down some test water?
Your vacuum blower attachment... blow down the tube (creating a seal around the drain)... and blow up the drain (from the bottom).
Hope that helps.
1998 Porsche Boxster
Old 09-28-2020, 01:08 PM   #3
Subman's Avatar
This:
https://www.amazon.com/Venture-1041-Trombone-Snake/dp/B0006VWY9I
Just the right size to clean out the drains. Maybe smaller than what you have?
2004 Boxster S - 50th Anniversary of the 550 Spyder
2000 Carrera Cabriolet
2016 BMW R1200R
1971 BMW R75/5
Subman is offline   Reply With Quote
Old 09-28-2020, 01:11 PM   #4
Shacky
I screwed up and pushed the tube through! Is there a relatively easy way to get under there? Remove battery tray?
