09-26-2020, 06:11 AM
Rear axle shaft failure
Had the L rear axle shaft fail and have sourced a new replacement. Question is should I replace R side now too? Any suggestions as to what should look for regarding condition of R side ?
10-03-2020, 03:46 PM
I would say yes..that way both are done at the same time line,..the other could go in a month,.Of course depending on the failure ? Frank
10-03-2020, 04:58 PM
Depends on what failed.
10-03-2020, 05:33 PM
What yr?
How many miles?
Base or S?
Do you track or just street?
Was a boot broken and throwing grease? How are the boots on the other side?
Tue I'm taking my Cayman in for boot replacement on the driver's side. I'm not changing the passenger side because the boots are fine, so the axle should be fine.
13 days to Indy!
1989 928 S4 5 spd - black
10-04-2020, 08:25 AM
To sum up - not enough information to give you the best recommendation.
If the CV boot was torn or loose just on this side, that would cause your CV joint to wear prematurely and fail. If this is what happened and the boot on the other side is ok, then no need to replace the other side.
If the CV joint is not what failed, for instance you cracked the actual axle shaft, then I would only replace the one side. It's unlikely to have a manufacturing defect on both sides.
If the CV joint failed, but the boot was not worn, and you have a high-mileage car, or you track the car, or you drive like a maniac, then I would replace the broken side and re-grease the other side. When you open it up to re-grease, if you see a bunch of metal in the joint, then you know it's time to replace the other side too.
As others have said, to really answer your question we need to know mileage, what exactly failed, how you use your boxster, etc.
10-04-2020, 02:33 PM
Will there be cake?
Sound advice...you say?
