Old 09-14-2020, 03:03 PM   #1
Puff of white smoke?
I have had my '99 Boxster for a few months. Pristine condition. Low miles. But twice now, after not having driven it for a few days, I start it and a puff of white smoke blasts out of the exhaust.
Normal, or cause for concern?
Thanks!
Stevenson927 is offline   Reply With Quote
Old 09-14-2020, 04:38 PM   #2
NewUserName
it means a new pope was elected...
DoninDel is offline   Reply With Quote
Old 09-14-2020, 05:23 PM   #3
Damn Yankee
TeamOxford's Avatar
Brilliant!
Funniest post I've read all year.
Just sayin'...........
TO
p.s. occasional white smoke is no cause for concern.
Old 09-14-2020, 08:13 PM   #4
Rickvd's Avatar
My understanding is that this is normal.
Rickvd is offline   Reply With Quote
Old 09-14-2020, 11:27 PM   #5
Stevenson927, common to boxster especially you the car was seated for few days. If just a quick white smoke from cold start and it goes away just before you drive it, nothing to worry. But if the white smoke stays for awhile or while driving it, first thing to replace is the AOS (Air Oil Separator) and maybe check engine will trigger also.
Not really hard to replace if you have a little knowledge with DIY cost only less than $140 for the AOS part.
ndfrigi is offline   Reply With Quote
Old 09-15-2020, 01:06 PM   #6
This would also happen if I parked my boxster on a steep angle downhill... oil must accumulate just right to puff. AOS is worth looking at/ installing a new one. About 2 hours of time and a 35$ part was what it took me on my first go around.
aparke4 is offline   Reply With Quote
Old 09-15-2020, 05:42 PM   #7
01 Seal Gray 986 S
bg305's Avatar
Make sure your oil isn't over full. I had an issue when the oil bars on the dash were completely full I let out a filter full and put the filter back brought it down one bar and it was great. My understanding is that it's a flat 6 engine so if the oil is slightly high it will sit higher than the ring and seep through as it sits.
bg305 is offline   Reply With Quote
Old 09-17-2020, 01:15 PM   #8
Thanks guys.
And the pope joke was lol literally!
