Old 09-10-2020, 03:33 PM   #1
TSP
No start, Help?
All,
My car is a 1997 986. We’ve had it for quite a few years and it has always been very dependable. Lately, it will sometimes fail to start. Turn the key and all the dash lights up, I can hear the fuel pump spin up but turning the key does nothing. I’ve read here and elsewhere and have replaced a few bits, mainly because it is coming up on 100,000 miles and I figured can’t hurt. The starter was replaced when the clutch and IMS were done a few weeks ago, I replaced the ignition switch and the micro switch on the clutch. Both keys have new 2032 batteries. The car battery was replaced last year. I took it to a reputable shop (no names to protect the innocent) and they thought it was sorted (starter replaced at time of clutch/IMS), but today, it did it again. What else could this be? I’m a decent backyard wrench, but not an electrician. Any ideas at all?
T
TSP is offline   Reply With Quote
Old 09-10-2020, 04:06 PM   #2
piper6909's Avatar
deleted. I was gonna suggest the switch on the clutch pedal, but I re-read your post and see you've already done it.
2010 Subaru Forester
Old 09-10-2020, 04:13 PM   #3
piper6909's Avatar
Check the post from Gilles on this thread. That could be your issue:
no crank, no start
Old 09-10-2020, 04:31 PM   #4
TSP
Thanks! Talk about fast. I looked in the fuse box by the clutch pedal. No relays. Where are they?
Old 09-10-2020, 04:51 PM   #5
Trunk left side behind the carpet trim.
Old 09-11-2020, 10:25 AM   #6
TSP
Found them. Took out the starter relay, looked normal. Didn’t bypass it, just rapped it on the heel of my hand a few times, greased connecting spades with dielectric and put it back in. Fired right up...
Although that’s what it does. Every once in a while, it just won’t start. Could go months of being fine, then one day, nothing. I’m going to order and replace the relay as they are inexpensive. I’m just hoping this isn’t an intermittent fault with the immobilized or computer. The worst part is I just don’t know how to troubleshoot all the possibilities.
Thanks for the advice, learned something, that makes it a good day!
T
Old 09-11-2020, 11:30 AM   #7
T
So first just about any relay is going to look normal.
What can happen to them is that the contacts inside the plastic case can get burned or more normally carbon up.
They are just as common as a fuse
They only cost about $10.00 and you can get them at any auto parts store.
So I always replace them when coming across problems like yours just so I know the relay is good.
I always go with the simplest things first and work my way up.
Old 09-11-2020, 11:50 AM   #8
piper6909's Avatar
+1!
You cannot judge relays by looks. My Subaru blower fan was working intermittently. To make sure it was the relay, I swapped it with the rear defroster relay and the fan works perfectly. I'll be buying a new relay for the defroster very soon.
Old 09-11-2020, 02:06 PM   #9
+1!
I changed out the relays for the DME/ECU and the fuel injectors when I purchased my 2000S two years ago.
Original relays so even though the car only had 47000 miles on it those relays were 18 years old.
I swear the car ran better after changing them.
