Old 08-17-2020, 02:34 PM   #1
North East UK
986 fuel pump sound
Hi guys. I noticed a buzz from my front end while I was running the car at a standstill. I suspected the fuel pump so I jumped the relay to fire up the pump and sure enough, there was the buzz. See this video:
fuel pump noise
So I switched out the pump and I'm pretty sure the noise is no different, see video:
replacement pump
At this point I'm open to suggestions, or is this sound normal and I've just never noticed it?!
Cheers guys.
BoxPaulie is offline   Reply With Quote
Old 08-19-2020, 04:16 AM   #2
North East UK
No one able to confirm if this is normal or not? Cheers guys.
Old 08-19-2020, 07:44 AM   #3
2003 S, Arctic Silver, M6
paulofto's Avatar
Are you sure it’s coming from the fuel pump? The only sound mine makes close to that is the SAI pump when I first start the car but only lasts a short time and goes off.
Old 08-19-2020, 07:48 AM   #4
North East UK
im pretty sure. I bridged the connection with a 12v after removing the relay for the fuel pump was the only thing running, unless the SAI runs from the same relay but i cant see it. Very buzzy... and im not sure if the new/used pump is any different or if its wishful thinking.
