Old 07-30-2017, 09:40 AM   #1
Block connector repair
Hi folks does anyone have a trick for repairing wires into block connectors, hopefully the image comes out, it is the plug for the alarm and tilt sensor it's gone rotten with the water run of from the bonnet etc, and seems to be screwing up the alarm and making the electrics flicker.
I can't just connect the wires without taking to bits the alarm module, so I need to fix the plug, can I buy new inserts for the original block connector solder the wires on, then press the inserts back into the plug/connector? Or is there a better way. I don't think I can solder the wires directly into the plug because the original inserts are a bit rotten.
This is on my 01 986 2.7 L
Nordy is offline   Reply With Quote
Old 07-30-2017, 10:24 AM   #2
You will have to remove old pins with a removal tool or (hopefully) a paper clip. Once you have new pins, you will crimp wires (don't solder).
The problem with soldering these wires is that with vibration, the solder connection can weaken and break as its not supported mechanically.
Old 07-30-2017, 10:43 AM   #3
Multi-Boxer Driver
Deserion's Avatar
I think the contact bush is why you need for the plug socket.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-30-2017, 12:52 PM   #4
Nice one , wasn't looking forward to soldering anything and didn't even think about a part number, thanks that's a lot of help.
Old 07-30-2017, 08:50 PM   #5
Pdwight's Avatar
Respectfully disagree on Soldering
It is the best connection you can have, crimp and then solder and it will never turn loose....if your car has enough vibration to cause a good solder joint to come apart then you probably did not survive the drive that caused it.
Old 07-30-2017, 10:37 PM   #6
On the slippery slope
JayG's Avatar
nice, well stated
2004 996 Targa Tip
Instructor - San Diego region
Old 07-31-2017, 06:27 AM   #7
I'm not in the UK but near me is a place called Terminal Supply and they sell everything for household or automotive electrical down to harness making supplies, connectors etc. Maybe there is a place like that near you or you can order online.
bwdz is offline   Reply With Quote
Old 07-31-2017, 11:17 AM   #8
I'm getting there, I've wriggled one of the contact bushes out of the block now, so I will have a go at getting one of the shelf , nice to know what it's called now and that there available.
Old 07-30-2020, 01:51 AM   #9
Mine seems to be the same. The wires have completely detached, resulting in the 'double beep'.
Does anyone know which wires go to which terminal?
KevM is offline   Reply With Quote
Tags
alarm , block connector , electrics
