Old 07-13-2020, 11:40 AM   #1
intake manifold gaskets
Install dry, or oil them or what? Any advice?
Luckyman01 is offline   Reply With Quote
Old 07-13-2020, 11:41 AM   #2
Yes........
Old 07-13-2020, 11:48 AM   #3
steved0x's Avatar
If it is the metal gaskets with a raised area all around, I installed them dry and the compression from the bolts squashed down the metal areas and made the seal, the water pump gasket was the same way, is that what you mean?
Old 07-13-2020, 07:18 PM   #4
Artist, 986S tinkerer
NewArt's Avatar
The green triangular gaskets can be placed dry. Correct me if Im wrong but I don’t see as it should make any difference.
