Old 01-31-2020, 08:42 AM   #1
2001 Boxster S with a 5-spd?
Hey guys, a buddy and I just went halfsies on a 2001 Boxster.
I’m very confused though. My understanding is that the base Boxster had a 5-speed manual, and the Boxster S had a 6-speed.
If you run the VIN on our car, it comes back as a 2001 Boxster S. Along with that, the giant emblem on the back of the car says Boxster S.
I haven’t crawled underneath it yet to look at the engine code.
Question: Is it possible that we have a Boxster S with the 3.2L engine that also has a five speed? Is that even a possible combination?
I think it’s a lot more likely that someone just slapped an “S” badge on the back, but I just thought I’d ask.
Regardless, we are excited for our new 986! Just trying to figure things out.
Iceman1183 is offline   Reply With Quote
Old 01-31-2020, 09:04 AM   #2
Motorist & Coffee Drinker
78F350's Avatar
It's not likely that it came from the factory like that, but after 20 years or so in the wild, just about any combination is possible. If your VIN checks good, you have the S model chassis, but the emblems and trim can be swapped out easily. If it had a failed engine or transmission, either or both could have been swapped.
Old 01-31-2020, 09:08 AM   #3
78F350's Avatar
Is reverse forward and left, or aft and right?
Old 01-31-2020, 09:27 AM   #4
LHD car as I'm in America - Reverse is towards the passenger and towards the rear.
So right and back.
Old 01-31-2020, 10:08 AM   #5
seningen's Avatar
odd -- check to see if its got a front center radiator. Also check the coolant hose diameters from engine to front of car.
A center radiator can be added -- but few folks would bother swapping to S coolant hoses.
The water/oil intercooler would be different too (top of engine)
Another difference would be a headliner to the convertible top.
No 3.2 (i.e. S) that I know of came with a 5-speed. And the 6 speeds are generally better trannys so
the likelihood of needing a replacement is much lower.
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 01-31-2020, 10:10 AM   #6
78F350's Avatar
So right and back.
That's the 5-speed then. Personally I've had a few combinations. A 2000 S model that had a 2.5L engine, S model center radiator and bumper on a '99, and a trunk lid from an S that was on an '01 base.
The taller oil cooler can be an indication, but for example: I just put an S model oil cooler on my '97 2.5L engine. Finding the engine serial number is the best was to know what engine it has.
Old 01-31-2020, 10:15 AM   #7
78F350's Avatar
Originally Posted by seningen View Post
... And the 6 speeds are generally better trannys so
Maybe someone threw in a cheap 5-speed to fix the six speed 2nd gear pop-out? Not the smartest solution, but you never know.
Old 01-31-2020, 10:31 AM   #8
Would not be a simple swap as the half shafts and uprights are different. I would check the engine number to see what it says...…….
Old 01-31-2020, 10:55 AM   #9
Newbie
So I'm gonna be that guy (sorry, just trying to cover all bases, haha). But its not just a 5 speed shift knob right?
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
Old 01-31-2020, 11:12 AM   #10
Lol. I mean, it's a 5-speed shift knob, but considering reverse is in the bottom right I would assume it's the 5 speed. if it was the 6-speed reverse would be in the top left, correct?
Sounds like I need to climb underneath and look at the engine serial number. I appreciate all the responses.
Old 01-31-2020, 11:24 AM   #11
Newbie
Your are correct. Bottom right for 5 speed. I was just being an @ss. Lol.
Old 01-31-2020, 12:25 PM   #12
If the fifth letter in the vin is an A then it's a base. If it's a B it's a S.
Woody
Old 01-31-2020, 12:49 PM   #13
That makes it a lot easier. VIN First 5 are WP0CA, so it’s likely a base chassis with the 2.7L and the 5spd, which makes a lot more sense.
Looks like someone just wanted to make it an “S” so put the emblem on the back I suppose...
Thanks for your help guys. I’ll still glance at the engine # next time I’m under the car.
Old 01-31-2020, 01:35 PM   #14
TRP
Yikes. I hope you didn't pay 3.2 / S prices
TRP is offline   Reply With Quote
Old 01-31-2020, 02:24 PM   #15
Definitely not.
Old 02-01-2020, 12:52 AM   #16
husker boxster's Avatar
That's Porsche option code 666 - Faux S Model.
1989 928 S4 5 spd - black
Old 02-01-2020, 04:54 AM   #17
TRP
Where did you run the vin and get back that the vin was for a Boxster S?
Old 02-01-2020, 07:25 AM   #18
Who's askin'?
maytag's Avatar
There's the question.
And is it TITLED as an S?
That would indicate some nefarious shenanigans in its past.
Old 02-01-2020, 12:47 PM   #19
Think my non-car-guy buddy ran the ViN and said it was an S. Lesson learned lol.
I think it’s on the up and up. Just someone wanted to fake like they had an S. Title is clean as far as I can tell.
Old 02-02-2020, 07:29 PM   #20
1997 Tip, 2018 Macan
rexcramer's Avatar
Originally, shouldn't an S have red brake calipers also?
