Alarm System keeps going off.
Hello running into an issue troubleshooting an alarm problem on my '01 986S.
Symptom: - note: LED alarm light doesn't seen to work, i am basing the flashes based on the clicks on the relay I hear (led light at the centre of the dash) - Blinkers/headlights will go off on a 2 flashes per second (continuously) closest alarm status seems to be door-safe mode. - The trigger appears to be when I use the windows / or it's a coincidence and it's at random. Since the LED light isn't on, I can only assume based on the clicking of the relay that the headlight blinking should be in sync with the LED light. (2 flashes/second - does not end or display a different pattern) The alarm control unit was sent in to ecu repair by the prev. owner. As needed I can send it into warranty if it appears this is the issue, but wanted to try troubleshooting before sending it back in. I've also already cleaned /checked the terminal connections for the alarm control unit. Connections look clean and good, but still cleaned it anyway. |
| All times are GMT -8. The time now is 03:44 AM. |
