Old 07-01-2020, 01:55 PM   #1
rggav
986 bucks/jumps up and down in 1st
I have a 2000 Boxster S and sometimes it bucks or jumps up and down in 1st when I take off. I have to slow down and it stops. What do you think the problem is?? I am thinking a bad clutch?? Car has lots of miles on it.
RG2000S is offline   Reply With Quote
Old 07-01-2020, 04:00 PM   #2
Keith Newby's Avatar
Others will jump in but my guess is the transmission mount is bad...take a look at the engine mounts as well.
Keith Newby is offline   Reply With Quote
Old 07-01-2020, 04:47 PM   #3
Qingdao's Avatar
Get a buddy to follow you while you take off. Get your buddy to keep an eye on your tail pipe in relation to the bumper. If the tail pipe moves up and down more than 1/2" your motor mounts/trans mounts are shot.
'98 PP13B powered "RX986"
Old 07-01-2020, 06:11 PM   #4
My 99 had the same issue until I replaced the front motor mount.......
-Eric
99 986
Eric-986 is offline   Reply With Quote
Old 07-02-2020, 06:16 AM   #5
rggav
Thanks for replies
Thanks for the replies. I am taking it to my repair guy to check.
Tags
clutch problem
