Old 05-29-2020, 03:12 PM   #1
Cam deviation numbers
Hi all, my 04 S has 84000 miles I am wondering when I plug durametric into the car to read cam deviation, should it be done when engine is running or just at ON position?
At engine Warmed up but not running I have a reading of camshaft position 1 at 1.09 and camshaft position 2 at 0.72, am I within spec or out? What range is considered acceptable? Your feedback is much appreciated.
kcphuah is offline   Reply With Quote
Old 05-29-2020, 04:03 PM   #2
thom4782's Avatar
Spec is +/- 9 so you are in spec. I believe you should take with the car running warmed up
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
Old 05-29-2020, 04:47 PM   #3
Kboggs's Avatar
Thats a great number, but is supposed to be taken at full operating temp, like right after a 30 minute drive, not warming up in the driveway.
Kboggs is online now   Reply With Quote
Old 05-29-2020, 05:12 PM   #4
The reading was taken when the engine was fully warmed up and has been driven for at least 30 minutes but should I have taken the reading when the engine is idling or just turned ON ?
Old 05-29-2020, 06:15 PM   #5
Idling
The spec is +/- 6 degrees not +/-9
Old 05-29-2020, 08:05 PM   #6
thom4782's Avatar
Blue62 is right +/-6 is the spec. Sorry about the misinformation. IIRC, codes start getting thrown about +/-9.
'87 951
Old 05-30-2020, 04:40 AM   #7
Artist, 986S tinkerer
NewArt's Avatar
Engine completely warmed up, engine running at idle. Reading should be stable within 6 degrees plus or minus.
Old 05-30-2020, 05:14 AM   #8
you are correct
Old 05-30-2020, 08:49 AM   #9
thank you everyone.
Old 05-30-2020, 08:00 PM   #10
So if you throw codes at -9 wouldnt that be a early warning for the IMS issue.??
Old 05-31-2020, 09:39 AM   #11
NewArt's Avatar
Not really. Very worn chain rails (guides) will cause this reading.
Old 05-31-2020, 05:17 PM   #12
Oh..Ok Thanks,.!! Newart.
