05-29-2020, 03:12 PM
#1
Cam deviation numbers
Hi all, my 04 S has 84000 miles I am wondering when I plug durametric into the car to read cam deviation, should it be done when engine is running or just at ON position?
At engine Warmed up but not running I have a reading of camshaft position 1 at 1.09 and camshaft position 2 at 0.72, am I within spec or out? What range is considered acceptable? Your feedback is much appreciated.
05-29-2020, 04:03 PM
#2
Spec is +/- 9 so you are in spec. I believe you should take with the car running warmed up
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
05-29-2020, 04:47 PM
#3
Thats a great number, but is supposed to be taken at full operating temp, like right after a 30 minute drive, not warming up in the driveway.
05-29-2020, 05:12 PM
#4
The reading was taken when the engine was fully warmed up and has been driven for at least 30 minutes but should I have taken the reading when the engine is idling or just turned ON ?
05-29-2020, 06:15 PM
#5
Idling
The spec is +/- 6 degrees not +/-9
05-29-2020, 08:05 PM
#6
Blue62 is right +/-6 is the spec. Sorry about the misinformation. IIRC, codes start getting thrown about +/-9.
'87 951
05-30-2020, 04:40 AM
#7
Artist, 986S tinkerer
Engine completely warmed up, engine running at idle. Reading should be stable within 6 degrees plus or minus.
05-30-2020, 05:14 AM
#8
you are correct
05-30-2020, 08:49 AM
#9
thank you everyone.
05-30-2020, 08:00 PM
#10
So if you throw codes at -9 wouldnt that be a early warning for the IMS issue.??
05-31-2020, 09:39 AM
#11
Not really. Very worn chain rails (guides) will cause this reading.
05-31-2020, 05:17 PM
#12
Oh..Ok Thanks,.!! Newart.
