-   -   986 coolant flush broken impeller (http://986forum.com/forums/boxster-general-discussions/77831-986-coolant-flush-broken-impeller.html)
Tlightfo 05-17-2020 04:43 AM
my impeller broke, now there are shards in the system...what is the best way to flush it out? hose up the thermostat hose, do i have to pinch off the front radiator hoses first, then do them after the engine flush, can i leave the water pump off when i run the hose into the system...back flush? please, i love my boxster, and want to TRY to get all the junk out and SAVE it...please help
Starter986 05-17-2020 05:02 AM
Do some research and reading. Asking for help about something that has been discussed on this forum many, many times (do a search) may be met with silence. Did you Google the problem? You'll find plenty.
When you run into a challenge... can't quite "get it"... then you'll find all the help you need right here.
Good luck.
Gjohn3707 05-17-2020 06:16 AM
Welcome
http://986forum.com/forums/boxster-general-discussions/29522-water-pump-impeller-blades.html
Subman 05-19-2020 12:59 PM
FWIW, on my car the PO had replaced the water pump after the impeller failed. Last year we pulled the oil cooler that sits atop the engine to replace the o-rings, which were leaking oil. While it was off we looked in the water side of the cooler & found a bunch of plastic shards from the impeller. Makes sense since it's one of the most restrictive places the coolant must flow through.
