Old 05-04-2020, 06:53 AM   #1
M9G
2002 2.7 Boxster in green
M9G's Avatar
2002 fuel filter question?
Had my 2002 boxster in for a service today and garage told me the fuel filter isnt where its suppose to be underneath, up in the tunnel behind the coolant pipes and they cant find it and did i have any idea where it was. From looking on google I think im reading that 2002 onwards the filter is in the tank.
Is this correct and is it correct it doesnt need changing?
M9G is offline   Reply With Quote
Old 05-04-2020, 07:04 AM   #2
A Porsche Guy
1PorscheBoxster986's Avatar
That is correct. Since 2002, Porsche made the filter inside the gas tank and called it a lifetime filter.
1PorscheBoxster986 is offline   Reply With Quote
Old 05-04-2020, 08:36 AM   #3
M9G
M9G's Avatar
Thankyou
Old 05-04-2020, 04:09 PM   #4
oof. So theoretically, it's supposed to last the life of the car, but after 18 years, I doubt it's as effective as it was on day one. Is there an easy way to R&R it?
hotdawwgman is offline   Reply With Quote
Old 05-04-2020, 04:56 PM   #5
Just gotta pull the lid of the gas tank,which is under the battery ,so run it to them almost empty and it should be simple unless the filter is within the fuel pump..then that's a bit pricey if you go for a new factory pump,.
flmont is offline   Reply With Quote
Old 05-04-2020, 07:18 PM   #6
Multi-Boxer Driver
Deserion's Avatar
The filter is in the sending unit, not the pump. Years ago I had to replace both since the filter was clogged and burned out (several) pumps. Chalked that to bad gas, no issues after.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
