98 Boxster transmission fill plug trying to cross thread
I picked up a Boxster late this winter and have been going through my 101 projects book with new clutch, flywheel, IMS, and RMS. Finally getting the car in the back together direction. I pulled the fill plug on the transmission since I felt it would be super nice and easy to handle while it's sitting on my bench.
After I removed the plug, looked at it and decided to call it a night, the plug is disagreeing with being threaded back in, and it's acting like it wants to get crossed up right away. I'm not sure if a piece of metal got stuck in the threads and jammed it up or if it just got a little goofy on me. Has anyone run into this sort of issue, or does anyone happen to know the thread specs on the plug that I can make sure they are ok before I keep going? |
Welcome to the forum.
You might try running an old tooth brush on both threads. Obviously you don't want to force it if it seems to be going cock-eyed.
Thanks, It seems to be lined up square, and tough to get crooked since it has the magnet on it as well. I just get it in a couple turns and it parks very firmly. Looking at the threads it doesn't seem like its really off, and they look pretty clean. I'll see about cleaning it all pretty thoroughly and give it another go.
If you are right up in there with some reasonable square pressure, rotate the plug as if you are undoing it and then the other way, clock wise to install. This helps start the threads square in many cases.
Guess it was just an issue of me learning about the car... the area the magnet slides into is connected to the linkages on the back of the transmission. without it being upright or those connected, the tube was no longer aligned with the fill hole so the plug was stopping when it hit it. Fiddling with the plug some as I tightened it solved the problem.
http://986forum.com/forums/uploads02...1588020833.jpg |
http://986forum.com/forums/diy-project-guides/62465-transmission-gear-oil-change-made-easy.html Good Luck |
Oof, yeah. I was moving it around a decent amount as well. this will be fun.
It appears as though I removed part 16, with the rubber gasket on it, which is still attached to the removed part. looking at the correct plug next to the driveshaft it's rather embarrassing how I came to that assumption. Thank you for steering me right |
Good Luck |
| All times are GMT -8. The time now is 06:48 PM. |
