Old 03-19-2020, 12:18 PM   #1
Headlight not clipping in.
Boxster 986
Headlight won't clip in 100% secure.
I'm actually afraid that if I have to brake really fast, it may pop off.
All the clips are good. gets into place just fine, but the clip just does not clip in like the other side does.
What can I do?
Fuzzuki is offline   Reply With Quote
Old 03-19-2020, 01:14 PM   #2
piper6909's Avatar
Is it an aftermarket headlight? If so, it may not have the lobes that hold the locking bar in place.
Here's a Porsche light:
You may note three lobes:
Some aftermarket headlights don't have them, and the bar slides down.
piper6909 is online now   Reply With Quote
Old 03-19-2020, 01:22 PM   #3
If you have had any body work done on that side recently, make sure there is nothing inside that is preventing the headlight from going all the way in. I had some bodywork done a few years ago and there was a metal tab coming out from the fender that was just a touch off and the headlight wouldnt go all the way in. Other than that, make sure all the tabs are going into their respective slots on the headlight tray. I also find it useful to use a 1/4 inch drive deep six point socket (it's the smallest one in my Harbor Freight metric set) with an extension and a ratchet, rather than the tool that comes in the tool roll with the car.
Old 03-19-2020, 01:43 PM   #4
Finnegan's Avatar
One of mine acted this way for no apparent reason once. Finally it just seated correctly. But I had the same fear that the whole assembly would just slide out when I applied the brakes. Oh, and I second the use of the socket rather than the official tool.
Old 03-19-2020, 04:54 PM   #5
It may be these tabs
Old 03-19-2020, 05:03 PM   #6
Yeah, that's it. I may have to try to build something up in that area.
Old 03-19-2020, 05:40 PM   #7
piper6909's Avatar
So you have aftermarket lights, then? Me too.
Here's a pic of mine, it has no lobes either:
Luckily, my car came with the original set in the frunk, so I was able to compare them and I noticed the difference.
I used the tool and wedged the lever against the body so it's constantly keeping back pressure on it. I also used a old caliper bleeder cap on the end of it so it won't scratch the paint (Not pictured). The tool stays in there permanently now and it works like a charm: (pic is upside down, sorry.)
The interesting thing is that the other side seems to hold OK. Only my passenger side was the problem.
Old 03-20-2020, 04:11 PM   #8
That's kind of a backwards fix. But if it works.
My drivers side is also fine.
I have 3 sets of old lights and none of the passenger side lights have tabs????
Old 03-20-2020, 04:25 PM   #9
piper6909's Avatar
HAHA! Yes it is, but it works brilliantly. There's a small bulge in the carpet when you replace it, but all in all, not bad at all.
I only have one aftermarket set, but if all of yours have tabs on the driver's side but not in the passenger side, then somehow it must be by design. The only thing I can think of is that the emergency release cable is behind the passenger light, so you can pull the light out and get to the cable. Not withstanding the fact that you can reach the cable from the wheel well, although not as easily. I actually moved mine to an easier to access location, so that'll never be a issue with me.
Old 03-20-2020, 04:46 PM   #10
I rerouted my cable to be behind the cap for the tow bar.
Old 03-20-2020, 06:11 PM   #11
piper6909's Avatar
That's a good spot. Many people move it there.
Old 03-21-2020, 09:32 AM   #12
I'm just afraid if somebody has to tow the car when I'm not there, it will get ruined.
Old 03-21-2020, 10:01 AM   #13
piper6909's Avatar
I doubt any tow truck operator will use it at all. They'll hook up underneath to pull the car onto the tilt bed.
Old 03-21-2020, 10:41 AM   #14
Last guy who took it to the shop for IMS and Clutch asked if I had the tow bar, and used it, even though the car was running, and I could have driven it onto the flatbed.
Old 03-27-2020, 01:18 AM   #15
Make your own lobes with tiny round head machine screws and nuts
