03-08-2020, 04:01 PM
Mysterious electrical device.
I was changing the evap valve on my Boxster's fuel filler pipe today and found some sort of electrical sensor hanging in there. It's rod-shaped, about 1 1/2" long and 3/16" in diameter, with an 8" lead on it that has a connector on the other end. If someone can tell me what it is and where it is supposed to go I would really appreciate it.
03-08-2020, 04:19 PM
Year would help.
Pics?
03-08-2020, 05:44 PM
1997 Tip, 2018 Macan
If your car is '97-'04, you need to have this PDF factory parts catalog. The expanded drawings should help you identify your part/number. They also have the newer catalogs if needed.
https://drive.google.com/file/d/1gUVtQYvav64U4tp_d9kATIHx0QWRfUAw/view
Please introduce yourself and post a pic of your car. Most of us are friendly and will be glad to help. Although some will bite when provoked. Safe travels.
03-09-2020, 05:42 AM
and it ain't real without pics
03-09-2020, 06:40 AM
Who's askin'?
Haha... that's awesome.
You're not talking about the Fuel Door Lock, are you? "Rod Shaped" and in that vicinity made me think about this.....
03-09-2020, 02:27 PM
I have been there, it is a sensor, if you look close it should be captured by the assembly that held the evap valve, it should be held laying on the fill tube.
03-10-2020, 08:16 PM
Thanks for all the responses! Special thanks to rexcramer for the parts pdf--I've been really frustrated by all the errors and omissions in the dealer parts diagrams. When I get some time (this weekend?) I'll introduce myself and my 2000 Boxster more formally.
03-14-2020, 05:49 AM
I was think that as well
05-09-2020, 11:14 PM
It's probably the OSVR reed contact which sits inside the bleeder valve just under your fuel filler. The bleeder valve has an orange circular face on it. There's a good article in pelican parts that shows you where it goes but there is an obvious recess inside the valve. Without it fitted, you may have a problem filling up. This is an issue that I've had for a while as my car doesn't have one nor can I find the wiring for it!!!
Sent from my ASUS_Z01KD using Tapatalk
05-09-2020, 11:16 PM
In fact if you can take a picture of the connector on the other end in place and where it leads to I'd be eternally grateful...
