Old 02-08-2020, 12:10 PM   #1
What is this dipstick on the top of the engine bay?
I was changing my air filter and saw a dipstick at the top of the engine bay, on the side towards the front of the car. It’s a short dipstick and it had nothing on it. What is it? I’ll post pictures if necessary.
Black_Boxster is offline   Reply With Quote
Old 02-08-2020, 12:14 PM   #2
Who's askin'?
maytag's Avatar
Your power steering? I'm trying to picture it. That's all I've got.
Old 02-08-2020, 12:21 PM   #3
Yes that’s it! Thanks
Old 02-08-2020, 04:59 PM   #4
Artist, 986S tinkerer
NewArt's Avatar
PS systems always seem to leak on these cars. And it's not like you can just pop the hood (bonnet) to check the levels every day or week!
Old 02-08-2020, 05:30 PM   #5
First time I checked mine? Dry as a bone!
Old 02-09-2020, 09:06 AM   #6
NewUserName
Priuses often have a dipstick behind the steering wheel...
DoninDel is offline   Reply With Quote
Old 02-09-2020, 11:13 AM   #7
piper6909's Avatar
I guess if I ever drive a Prius, there will be 2 dipsticks behind the wheel!
Old 02-09-2020, 06:43 PM   #8
husker boxster's Avatar
Be sure to use the proper PS fluid, not just any garden variety fluid. It requires synthetic fluid. Pentosin chf 11s is recommended and surprisingly can be found in some parts stores.
Boxsters and Caymans have a reputation for having PS issues on the track. My contention is people don't check their fluid level and blame track time for the failures. I check my level before every DE and have never had a problem, including 20-turn COTA.
1989 928 S4 5 spd - black
Old 04-19-2020, 06:12 AM   #9
Related question: When you check the levels on these, does one twist the dipstick down tight, then unscrew and read it? Or should you just push it firmly in place (without screwing it down) and then pull up and read?
Old 04-19-2020, 08:45 AM   #10
piper6909's Avatar
Screw it down, but realistically there's very little difference in the readings between the two methods. It doesn't need to be that accurate anyway.
Old 04-19-2020, 08:48 AM   #11
I would think screwed down tight would give the best reading,.but just add a little at a time untill stick reads full ..Frank
Old 04-23-2020, 08:00 PM   #12
It's hydraulic fluid, needs to be checked hot. I don't remember, but the stick may have a hot and cold line. It's not a bunch different. An OZ or two.
Old 04-24-2020, 08:27 AM   #13
Yeah, it's got a "hot" and "cold" scale on it, front and back.
And the high end and low end aren't very far apart, kind of implying to me that getting it filled accurately must be at least somewhat important. But I agree with you piper, I can't imagine why it would be that critical..
