Old 02-02-2020, 08:15 PM   #1
Oil splash valve/oil spray jet test
Hey Folks,
I removed the oil spray jets from the crank bearing carrier, or as the manual calls it, splash valves with the intension to test/clean them. Any idea how to do this? At what pressure should they open? Or should I just replace them? They are not expensive, but I could use that money for something else for sure..
Thanks,
Greg
Old 02-04-2020, 09:58 AM   #2
BYprodriver's Avatar
Use compressed air to blow out the jets, most should obviously be fine. If not soak in Simple green or similar mild solvent followed by compressed air. That's what i did for my engine rebuild & reused them all. ("Maytag")
Old 02-04-2020, 10:38 AM   #3
Who's askin'?
maytag's Avatar
you called?
Perhaps I misunderstand your "Maytag" tag?
What can I do for you? How can I add to this topic?
Old 02-04-2020, 12:47 PM   #4
Ok, thanks. I ordered new ones already, but I`ll save the old ones.
Old 02-10-2020, 03:01 PM   #5
spin or no spin
So I received the new set of splash valves, and I`m a bit puzzled because the brass jets are not moving in the new ones, but in the old ones I can easily rotate them relative to the aluminum part. Should they be spinning during operation? If not, does the orientation matter?
Thanks for any input.
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
