Old 02-01-2020, 07:37 AM   #1
Switched live in front boot.
Hi does anyone know if there is a switched live near the battery or under any of the front wings
Blue99 is offline   Reply With Quote
Old 02-03-2020, 06:08 AM   #2
TRP
Do you have an amplifier or CD changer up front? Of so, you can start looking at the big red plug or the smaller black plug to the amp. Big red / Maroon plug is mostly speaker out. There were two wires on one end that I didn't use. The smaller plug was line level in. May have a smaller wire there. Other side of the frunk should be the CD changer harness. Check there.
TRP is offline   Reply With Quote
Old 02-03-2020, 08:08 AM   #3
on my 2000S there is a small bundle of wires just behind the battery on the negative side. I taped into a Black with yellow trace wire in that bundle for the DRL's I installed. So if the key is on my DRL's are on.
Old 02-04-2020, 10:01 AM   #4
Thanks. I also want to install DRL’s again thanks for the help
