Old 07-05-2020, 01:21 AM   #21
qstoria's Avatar
And what colour is the Instrument dial background? Black is base and white is S.
Base has a lower top speed from memory but I can't remember what they are in miles.
Sent from my CPH1979 using Tapatalk
qstoria is offline   Reply With Quote
Old 07-05-2020, 02:53 AM   #22
Careful. My base has a white gauge cluster. Either it was an option or someone swapped it out on mine.
beater986 is offline   Reply With Quote
Old 07-05-2020, 02:59 AM   #23
qstoria's Avatar
Very valid point. I didn't consider the possibility it was an option (or could have been swapped) !
Old 07-06-2020, 04:10 PM   #24
Phat Hippy's Avatar
Iceman, Door sills will say "Boxster S", "batwing" console emblem will be "Boxster S", Brake disks will be larger and drilled along with red calipers. A lot of those things could be changed to deceive, but some changes could be innocent owner up-grades to a base model. Unless someone has access to free or reasonably priced used S model parts, it is unlikely they went through the trouble/cost of adding these. Why would they? Evil intent comes to mind. LOL. Emblem parts are easy to buy and add. If a previous owner added an "S" to the trunk without replacing the "Boxster" script, it would be slightly off location. Good luck and enjoy your car. If it has a 3.2 and six speed manual with the S model brakes it won't matter while your driving it.
Phat Hippy is offline   Reply With Quote
Old 07-09-2020, 05:03 AM   #25
White dials were an option on the 2.5 when new (as were a lot of other options available
as standard on the S) so not necessarily a good indication.
jonogt6 is offline   Reply With Quote
