Old 12-30-2019, 06:23 AM   #1
water pump replacement
Does anyone know how hard it is to replace the water pump and thermostate or what the dealer charges to have it done approximate
Jimbo409 is offline   Reply With Quote
Old 12-30-2019, 06:29 AM   #2
piper6909's Avatar
Pelican Parts has some great how-to articles. Here's one on the water pump and t-stat.
https://www.pelicanparts.com/techarticles/Boxster_Tech/34-WATER-Thermostat_and_Pump/34-WATER-Thermostat_and_Pump.htm
There are plenty of great threads with great tips on here as well, just do a search.
Old 12-30-2019, 07:18 AM   #3
kk2002s's Avatar
Many on this forum know how hard this job is.
It's a messy job as you have to deal with the coolant. It's not as frustrating as replacing the coolant expansion tank as most bolts on the WP are accessible. A couple are challenging. Then you have to replace lost coolant and make sure system is purged of air. I found this a good time to flush and replace my coolant.
Seal Grey
Old 12-30-2019, 07:59 AM   #4
It isn't even close to impossible, no special tools are needed. Like lots of things on the Boxster engine it's a little tight and you need to access from under neath and through the panel behind the seats. We don't have a gauge of your abilities or limberness, tho. Things that might be easy for most of us might be difficult for you.
I wouldn't have it done at the dealer, they charge inflated parts and labor prices. An independent European repair garage would be appropriate. Go with their parts recommendation, you really do want pump with a fiber impeller, eventual failure won't grind up the front of the aluminum engine. OEM is expensive, but the best.
If you're a newbie or inexperienced diy mechanic, I'd do it myself. You never learn if you don't try new things. The one time I tried to rebuild an old Toyota automatic transmission, I found out that I shouldn't do automatics--ended up converting the car to a 5 speed from a wrecked one.:dance:
Good Luck.
2001 Boxster
2007 Toyota Highlander
Old 12-30-2019, 12:20 PM   #5
1998 Boxster Silver/Red
On my own I replaced the WP. The coolant... that's the biggest drag as it can get messy.
I did my motor mount at the same time... and it made replacing the water pump a breeze, figuratively speaking. Yes, there is a WP bolt or two that can be challenging but, with the motor mount at the same time... hardly as chalennging, and a breeze.
1998 Porsche Boxster
Old 12-30-2019, 01:20 PM   #6
On many instructions it is adviced to take two WP bolts off from inside the cabin. I did this on my first WP change - a real pain in the ...
Second time a round I unbolted and rebolted all WP bolts from undernath the car and it was waaaay easier.
My car is 2001 Boxer Base with manual transmission (probably does not make a difference between 986's).
Also not very messy since I was able to use a lift in my friends shop and was able to stand under the car
2001 996 C2 Manual
Old 12-31-2019, 07:20 AM   #7
what is approximate cost to have dealer or independent shop do the wp rough idea jimbo
Old 12-31-2019, 08:02 AM   #8
Rob175's Avatar
I just had a new water pump installed by my "indi" shop (in the Chicago suburbs) on my 1998 Boxster (w/85,000 original miles). The total came to $1,100 for parts, labor, coolant etc. Since the car has been virtually trouble free for the 20 years I've owned it I consider it just normal ownership costs. YES, of course I could have saved money by doing it myself but that's just not my thing and I have no way to work from under the car. The original WP lasted 20 years so I'm hoping to get another 20 from this new pump....lol.
Old 12-31-2019, 08:58 AM   #9
It's true about doing the motor mount at the same time. Makes access much easier.
Also, IIRC, some of the bolts holding the WP in place are different in length—make sure you keep straight in your head (I believe I actually made a little diagram) which ones go where.
Seems to be a big difference of opinion on this. I got probably 10-12 years out of mine. (I'm assuming that the one I removed was original—the car only had 19k miles when I got it.) OTOH, Jake Raby (the "Engine Surgeon" who used to post here regularly, a pretty knowledgeable guy when it comes to the M96) advised changing them out every 3 years.
Old 12-31-2019, 09:25 AM   #10
Simple job: not worth paying someone to do. The burping is the hardest part.
-H. L. Mencken
Old 12-31-2019, 02:40 PM   #11
Artist, 986S tinkerer
NewArt's Avatar
No big deal. Pierburg water pump. Do the low temp stat while you’re in there. An Airlift tool makes coolant refill a breeze.
Old 12-31-2019, 07:37 PM   #12
1997 Tip, 2018 Macan
rexcramer's Avatar
An Airlift tool is worth every penny. It is fast, easy and works as perfect as the YT videos show.
Old 12-31-2019, 09:49 PM   #13
JayG's Avatar
Replacing the WP is a little bit PITA, but very doable DIY. Just plan on replacing the unicorn sperm they call Porsche coolant when you do it.
As newart mentioned, put in a low temp thermostat "while you are in there" also consider replacing the motor mount as well. Lots of threads on this
You can get a pierburg (OEM quality) at a reasonable cost. When I did mine a few years back, IIRC it was around $350 for the WP, low temp thermostat and the Porsche brand coolant. I got it all from ware house 33 auto dot com (remove spaces ) and put rennlist in the promo field for an extra 10% off
Old 01-01-2020, 07:32 AM   #14
Xpit77's Avatar
As crazy as this sounds check Amazon. If your not using OEM.Because the early 2.5 are a dying breed and there`s lots of rebuilts sitting on shelves that need to be moved.Worth the look.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 01-01-2020, 06:45 PM   #15
More of a truck guy
Where would one look for a 2.5L that has been rebuilt?
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
Old 01-02-2020, 05:40 AM   #16
Xpit77's Avatar
Wps are either OEM or remanufactured.Before I bought I checked with my indie.I bought a pump on Amazon Prime for $98. CND.Regular price $249. It was from a company in New Jersey.Came with the complete gasket.No core return.
99 Boxster sold
88 944S sold
71 Opel GT sold
Old 01-02-2020, 06:28 AM   #17
JayG's Avatar
Don't be a penny wise and a pound foolish when it comes to your WP
Lots of threads about water pumps do a search and read them
YMMV
Old 01-02-2020, 10:38 PM   #18
The WP isn’t particularly bad to change. The upper t-stat housing bolts will create a few sentence enhancers. You WILL spill coolant, you WILL wear some coolant at some point as well. As others have said, purging the system of air as defined in the manual is the biggest PITA of the whole job... doing a WP is good pre-Zen work for when you have to do the alternator...
Old 01-03-2020, 05:24 AM   #19
I had my alternator rebuilt a couple months ago. Removing it was a piece of cake. reinstalling it presented a challenge. The water pump I replaced myself and found it more time consuming that the alternator (jacking the car... replacing the MM at the same time).
I'd rather change out the water pump.
Old 01-03-2020, 11:00 AM   #20
pilut2's Avatar
I found all bolts on WP and t-stat surprisingly easy to access, even with the motor mount in place. The worst part of the job was definitely the mouthful and eyeful of coolant!
pilut2 is offline   Reply With Quote
