Old 01-06-2020, 08:33 AM   #1
Ukr986's Avatar
PowerFlex Sway Bar Bushings Sizing
Hey guys,
I am looking into getting new bushings for my front and rear sway bar bushings. After reading through various other threads on sway bar sizes I cant seem to find which ones suit my car. I've found the sway bar sizes below but the size options they offer on powerflex does not match up. Was wondering if anyone has bought these for their boxster
Front bars:
986 non-s standard suspension 23.1mm diameter 3.4mm wall thickness
986 non-s M030 suspension 23.6mm diameter 3.5mm wall thickness
986 S standard suspension 23.6mm diameter 3.5mm wall thickness
986 S M030 suspension 24.0mm diameter 3.8mm wall thickness
996 GT3 Bar 26.7mm diameter hollow
Eibach bar 24mm solid
Rear bars:
986 non-s standard suspension 18.5mm diameter 2.5mm wall thickness
986 non-s M030 suspension 19.6mm diameter 2.5mm wall thickness
986 S standard suspension 18.5mm diameter 2.6mm wall thickness
986 S M030 suspension 19.0mm diameter 2.7mm wall thickness
Ukr986 is offline   Reply With Quote
Old 01-07-2020, 01:30 PM   #2
Ukr986,
You may want to contact Lynn at Powerflex and ask him which bushings he recommends for you, perhaps be best if you provide the diameter of the sway bars you have on the car.
Contact info:
Lynn Campbell
TF: 855.374.1877
PH: 540.307.4505
Lynn@PowerflexUSA.com
www.PowerflexUSA.com
Gilles is offline   Reply With Quote
Old 01-08-2020, 04:01 PM   #3
edc
550 Anniversary
edc's Avatar
I have the Black series on mine. Didn't DIY as done as part of some other works so unfortunately cant resolve your question.
