Old 10-27-2019, 04:46 PM   #1
Question What are these plastic parts floating in coolant tank?
2004 Boxster S, 98K miles, new to me in the last few weeks. Noticed coolant was a smidge below the min line, and I thought I had checked that before, so I dutifully pulled up the trunk carpet to inspect the tank, look for evidence of leaks on the floor, etc.
Quite clean in the floor. I don't think this tank has been leaking. The tank itself looks good, not yellowed, and shows part number 996.106.(7?)47.09, made by Geiger Technik. Pelican lists the 996.106.147.08 as the tank for this car. Perhaps it has been replaced recently?
Peeked down into the tank itself before adding a splash of distilled water, and saw a plastic part floating down there in the coolant... poked that around with a probe to see what it was... it looks just a bit too big to be able to come up and out through the filler neck... which makes me think that part was actually born there and belongs there somewhere. But it seems to be loose. And it has a friend. Both are loose, untethered, as far as I can tell. I can roll them around with a probe.
Larger floating plastic piece on right in this pic, smaller clear plastic cap-looking piece to left.
What are these? I haven't seen a new tank up close, so I don't know what's in there. Perhaps the coolant level float (if there is such a thing) has come loose? Any clues appreciated.
mhowellaz is offline   Reply With Quote
Old 11-22-2019, 10:19 PM   #2
For anyone else who comes by with the same question: I visited an indy shop. They said coolant level sensor parts broke loose in the tank. Looks to them like the tank is original, but as good as it looks (not yellowed, no leaks, 15 yrs old), this bit has failed. Gotta watch coolant level carefully until I replace the tank... presumably the coolant level light won't work if this sensor is not working.
Old 11-25-2019, 05:40 AM   #3
Rob175's Avatar
Hummm....not sure about the accuracy of that reply. Typically the sensor is NOT in the tank....rather it sits in a channel molded into the bottom of the tank. If it needs to be replaced it can be pulled without ever draining the tank. The sensor does not use a "float" inside the tank, it's purely an electro magnetic wired sensor. It DOES NOT SIT IN THE TANK
Rob175 is online now   Reply With Quote
Old 11-25-2019, 09:21 AM   #4
It’s dead on accurate.
How do you suppose that sensor knows the coolant level? It can’t see it
The float tells the sensor the coolant level via a magnet in the float that the sensor “senses”.
Old 11-28-2019, 06:17 AM   #5
Rob175's Avatar
Respectfully disagree.....there is NO FLOAT in the coolant tank.....the senosr simply senses the fluid level by measuring resistance of liquid vs. air (or no liquid). Feel free to point out, on the diagram where the float or sender or magnet INSIDE the tank is.........answer, there isn't one, sorry!
Old 11-28-2019, 07:18 AM   #6
The coolant level sensor does not sit in liquid coolant.
It sits in a tube, isolated from the fluid inside the tank.
The sensor is a magnetic reed switch, not a resistance sensor.
It’s the float
Old 11-28-2019, 07:23 AM   #7
Here you go
How the coolant tank sensor works
Old 11-29-2019, 05:01 AM   #8
Rob175's Avatar
OK....I'm wrong....my error.
Old 11-29-2019, 08:59 AM   #9
1998 Boxster Silver/Red
Particlewave. Kills. It. Again.
He's one of my three (3) "Go-to" members when I'm in a pinch. I'll do my research... entertain some suggested troubleshooting, corrections, modifications, replacments, repairs... and it always lands on one of the three. Further, they're 99.99% spot on. That saves me some headache and, more importantly, some quid. Me likes the quid.
Happy Thanksgiving!
1998 Porsche Boxster
Old 11-29-2019, 05:21 PM   #10
+++That^^ !
I never argue with pw...it's a losing proposition (coming from one who is decidedly NOT one of the other two!).
He accurately explains all kinds of stuff—hell, he's even hands-on fixed stuff for me that I'd not had a clue about. May he stick around here forever...at least til I sell my Box!
Old 11-30-2019, 07:20 AM   #11
Originally Posted by Frodo View Post
+++That^^ !
Yeah... we know you'll never sell the Box.
Old 11-30-2019, 08:16 AM   #12
Thanks @particlewave and @Rob175 for weighing in on my little mystery, now solved!
Old 11-30-2019, 10:58 AM   #13
Yeah, you're probably right about that. With 104k, I might as well go ahead and play the hand I'm holding..
