Old 10-17-2019, 12:07 AM   #1
Porsche Boxter 986 2.7 smoking still after AOS Change
Hi Guys,
Has anyone know a way around diagnosing the problem I have here.
The car had a ton of smoke coming out the back - replaced the AOS - it still is smokey but not as much - upon observation it seems like an unburnt fuel smell. Changed the oil - changed the coolant - replaced sparks and O2 sensors. Done a diagnostic test with the durometric software - got the following error codes. Cleaned the plenum internally and replaced the throttle body.
PO300 - Porsche fault code 62 - Misfire damaging to cat converter
PO301 - Porsche fault code 63 - Cylinder 1 misfire damaging to cat converter
Can anyone shed some light on next steps??
Thanks in advance.
Kimo is offline   Reply With Quote
Old 10-17-2019, 05:59 AM   #2
piper6909's Avatar
I don't know about the smoke, but you can try swapping the coil from cylinder 1 with another cylinder. If the misfire moves to the other cylinder you need a new coil.
piper6909 is online now   Reply With Quote
Old 10-17-2019, 08:25 AM   #3
BYprodriver's Avatar
Originally Posted by Kimo View Post
Hi Guys,
Thanks in advance.
Most likely the AOS failure allowed enough oil in Cylinder # 1 to foul the spark plug.
Old 10-17-2019, 08:27 AM   #4
piper6909's Avatar
That's what I was thinking, but he said he changed the plugs, though.
Old 10-17-2019, 12:24 PM   #5
most likely a bad coil and/or cracked spark plug tube. I would do AOS also if I didn't know the age or mileage. Typically when one coil/tube fails the rest aren't that far behind. Might as well do them all, all new plugs and throw in an AOS. Clear the codes after and then take it for a drive.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
