Trailing Arm/Drop Links
Hi All,99 Boxster Base. Need to replace my trailing arms (rear) and all drop links. EPS or TRW thats the question. Any preference? V
TRW arms were cheap on Amazon a few years ago...Drop links are cheap anyway so might as well go OEM.
eps design is suspect.
TRW all the way |
TRW except the Lower control arms as you can't find those anymore.
the type of bushing they use in that area does not articulate in the same sway as the stock plastic ball. There is also evidence of one of these EPS arms breaking in the 996 forum on rennlist.
What type of bushing is it that they use?
I am genuinely curious about the EPS suspension bits because I was looking to refresh my suspension system and did reach out to a handful of 996 guys on Rennlist, and most seemed happy with their decision. Another option I was looking at was Elephant Racing, and then the thread where one owner tracked their 996 (or was it 997?) where the control arm or something broke, but it seemed to be a one-off more than the norm than anything else. I chose not to go with Elephant Racing and EPS simply because they weren't readily available to us in Canada, and time was of the essence for me (car was already on the shop hoist, so time was a-ticking.) Understand that I try to keep an open mind about what products to buy for my car, and try to make an informed decision on my purchases, and that the community has a reference point on how to make their decisions. I am in no way trying to support or villainize any vendors our there. |
I think I read on Rennlist it was an EPS arm that broke.....Anyway....I went w/ TRW for the track arms and drop links. The ride is less clunkier not a big difference but better. I guess a Boxster ride is pretty hard. V
https://www.youtube.com/watch?v=GoQ7LR6AuaQ This could be why rennlist has posts of them breaking. |
I bought the EPS front arms recently to give them a try. So far I like the feel although there is not much of a noticeable difference on the road. I was able to easily change them my self in less than an hour using a shop lift keeping the wheels under load. Honestly, I don’t think they will break easy, but if they do, it is what it is.
I am not familiar with the Rennlist description of a failure/s . Does anyone know how many documented failures are out there ? Just curious how many failures vs. number sold . Is it 1 out of 100 ? 5 out of 1000 ? 98 out of 100 ? I bought a rear set of EPS a few years ago and haven't gotten around to installing them yet . Every component on a vehicle fails at some point that's why we replace parts . But a catastrophic failure is a different issue . Any feedback on actual numbers ?
so, the oem trailing arms are on a ball at the inner connection point - as a result the outer end of the arm can move up and down as well as in and out.
the eps trailing arms are on a bushing such that they can move in and out but not up and down. the inner trailing arm connection point is tied to the body of the car and is fixed, however the outer point is tied to the control arm. the control arm moves up and down as the damper compresses and rebounds and, as a result, the outer end of the trailing arm needs to be able to move up and down. note that the role of the trailing arm is not to resist the up/down motion of the control arm, but rather to keep it from moving forward/backward (caster). the eps trailing arm bushing doesn't allow this motion, but the suspension still has to compress; as a result the deflection occurs in the arm itself. making it all worse is the design of the arm itself. if you look at it, it looks like a little 'I' beam. I beams are designed to be strong in one direction; how the eps arms get loaded is the perpendicular direction - where they have no strength (on the front, anyways). |
I bought a set of MTC links off ebay and I'm happy with them. Price for pair was roughly the same as 1 TRW. But I haven't seen them on ebay anymore.
I wouldn't put one on my car, FWIW. Steve |
Edit: I’m not trying to say that the arms will not break. But, I’m more than willing to “field test” them and provide a feedback if they break. |
If the EPS is ruled out as an option and folks don't like the standard OEM is there a " better than OEM " part available ? Same ball design but heavier duty/longer lasting ?
I have the EPS arms on the front of my 2002, and they haven't broken and killed me so far. I bought them because I thought they would have less deflection under heavy braking. Since I track the car, that sounded like a good thing.
| All times are GMT -8. The time now is 05:33 AM. |
