Old 10-04-2019, 05:16 PM   #1
sfkjeld's Avatar
Airbag warning light
Came on the other day. Are there any common causes for this? I put new rubber grommets in the steering wheel earlier this summer because the Horn was beeping occasionally. Never had the light until this week tho. Suggestions?
sfkjeld is offline   Reply With Quote
Old 10-04-2019, 05:24 PM   #2
piper6909's Avatar
Did you by chance pull the front seat for something? If so, and you turned the ignition on without the harness under the seat connected then you'd get an airbag light.
If you didn't do anything that would cause the light, then you'd have to have it scanned to find out what the problem is.
Old 10-04-2019, 05:56 PM   #3
Could be the seatbelt. On mine the driverside seatbelt latch sensor was bad and I had to replace it.
Sent from my SM-N960U using Tapatalk
mmassey0125 is offline   Reply With Quote
Old 10-04-2019, 05:58 PM   #4
here is the part
Old 10-04-2019, 06:19 PM   #5
Scan it and get the code(s), replacing parts without actually knowing what is wrong is stupid and generally a waste of time and money.
Old 10-04-2019, 07:49 PM   #6
01 Basalt Metallic 986
JimmyBad's Avatar
In addition, you will need the scanning tools to reset the light after repair.
JimmyBad is offline   Reply With Quote
Old 10-05-2019, 10:30 AM   #7
sfkjeld's Avatar
Do you mean the Porsche scanning tool or would a generic ODB2 tool show me codes related to the airbag light? I have an Autel AutoLink. It is showing no codes on my 2000 base Boxster.
Old 10-05-2019, 12:18 PM   #8
piper6909's Avatar
I have several scan tools and the only one that cleared the airbag light on the Porsche was my Durametric. There may be others that can do it, but I don't know of them.
Old 10-05-2019, 01:20 PM   #9
JimmyBad's Avatar
That. And I know that there is Launch that can do it.
Old 10-06-2019, 02:49 AM   #10
sfkjeld's Avatar
Thanks. It appears the Launch scanning tools come in a wide range of prices. From $46 to thousands on Amazon. Any idea which model will clear the airbag light?
Also, I noticed the lever for adjusting the seat back on the drivers side appears broken. Have no idea when nor how that happened.
Old 10-06-2019, 08:34 AM   #11
Possibly a dumb question-has anyone ever tried disconnecting the battery to reset the airbag light?
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
Old 10-06-2019, 10:48 AM   #12
piper6909's Avatar
Doesn't work. I tried.
Old 10-06-2019, 12:21 PM   #13
Darn. I was doing work on my door recently and needed to adjust the window. Forgot to plug the airbag back in before doing so.
Old 10-06-2019, 02:21 PM   #14
JimmyBad's Avatar
The Launches that I did it with is in the thousands. If I were you a durametric would be the best choice.
