Old 08-22-2019, 04:21 PM   #1
Question 1999 Boxster oil leak
Got under Porsche today searching for elusive oil leak and saw a wet area on driver side , forward section of engine . Looks almost like timing chain cover. Anyone ever had oil leak in this area? My search started because after sitting in garage for a few days, clutch is real grabby for first 3-5 miles then normal. I suspect oil is somehow getting in clutch plate. But, oil level never goes down between 5k oil changes. Power steering the same way, that leaves AOS which was changed 6 mos ago. Any ideas?
Tmar04 is offline   Reply With Quote
Old 08-23-2019, 01:58 AM   #2
have you looked at the oil pressure sensor?
these can fail and cause a relatively small leak
KT
Sent from my SM-G390F using Tapatalk
KT986 is offline   Reply With Quote
