Old 08-08-2019, 02:10 PM   #1
Is this dealer story credible
My 2000S had the airbag light come on and threw the drivers seatbelt code, the dealership is saying that the seat belt and the harness under the seat, both need to be replaced. They have a harness kit Porsche part 000-043-206-06. Resistance has built up in the harness over the years.
Is this any experienced before, is it credible?
David
Luckyman01 is offline   Reply With Quote
Old 08-08-2019, 02:32 PM   #2
It will be the buckle and harness, but not the belt itself. Fairly common and a simple fix.
Old 08-08-2019, 07:44 PM   #3
Been there done that shortly after my purchase 3 years ago at 60K miles. New buckles and repair kit with gold-plated connector pins. And Autel scanner that is able to reset airbag light.
Old 08-09-2019, 06:33 AM   #4
legit then?
So it sounds like the concept of needing to replace the harness is legit, plug and play or cut and solder?
David
Old 08-09-2019, 10:52 AM   #5
Jay
Boxstard - which (model) Autel scanner
I am looking to buy a inexpensive but decent (if that exists) OBD scanner - any particular manufacturer and model recommendation?
2003 Boxster-S.
Black with Tan interior.
jay2015 is offline   Reply With Quote
Old 08-09-2019, 10:57 AM   #6
Either the Autel MD802 or Autel DiagLink (same machine and capability, but the $175 MD802 comes with all makes/models preloaded and the $95 DiagLink comes with one make of your choice, additional makes can be downloaded for $10 each).
Sounds like the DiagLink is what you want. Choose Porsche as your starter make and buy others when needed.
It can do almost everything the Durametric can (actual values, reset airbag, etc.).
Old 08-09-2019, 04:13 PM   #7
morgal48's Avatar
+1 on the Autel MD802. I use it on my Boxster, Volvo and GMC 6.6L diesel.
2000 Boxster S
2010 Volvo XC60
2011 GMC Denali HD 6.6L (sold)
2008 Cayenne S (sold)
1989 Targa (sold)
morgal48 is offline   Reply With Quote
Old 08-12-2019, 06:33 AM   #8
orginal inquiry
Does anyone know if this is plug and play or cut and solder?
Old 08-12-2019, 09:51 AM   #9
looks like its snip and splice. If you google the part number listed above, a picture of the kit comes up.
2001 Boxster
2007 Toyota Highlander
Old 08-12-2019, 10:00 AM   #10
I've got this one: https://www.amazon.com/Autel-AL619-Autolink-Automotive-Diagnostic/dp/B0091DJWV0
$99 at Amazon
All I need for my 01 Box. It will even reset the airbag system.
2001 Boxster
Old 08-12-2019, 12:48 PM   #11
I went with the diagalink, only thinks it cannot do so far is display the ABS and instrument cluster faults
