Old 05-27-2019, 09:21 AM   #1
Jakeg104
Roll Bar Trim tabs?
Hello Folks,
Installed a Brey Krause rollbar for trackday, now want to put back the rollbar trims on the rollbar, but the 'tab's seem to have disintegrated. I'm having a tough time finding the part number for just the tabs/locks. Would someone be able to point me in the right direction?
Thanks in advance!
Jake
2000 Boxster S- Silver/Boxster Red
'11 458 Coupe
91 Brilliantrot e30 M3- Restored to Factory
'17 RR SC
jgopinath is offline   Reply With Quote
Old 05-27-2019, 09:59 AM   #2
piper6909's Avatar
There's nothing wrong with those tabs. Just unscrew them from the trim pads and push them into the holes on the roll bar. Then you can push on the pads.
Old 05-27-2019, 10:00 AM   #3
Need For Speed
KRAM36's Avatar
Are you looking for these? Part # 98658075100
2003 Boxster S
Old 05-27-2019, 10:24 AM   #4
Jakeg104
Brilliant! you're right and it worked, thanks!!
Appreciate you sharing the part numbers! If they do break when i pull them off the for the next DE event (a few are starting to look a bit ratty), this will be perfect!
'11 458 Coupe
'17 RR SC
Old 05-27-2019, 12:37 PM   #5
Racer Boy
Racer Boy's Avatar
They will eventually need to be replaced. After all, those plastic pieces are 20 years old! After taking the padded trim off and on about ten times, my plastic bits finally broke apart. At least they are relatively inexpensive!
